ALSA: cs5535audio: constify cs5535audio_dma_ops structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The cs5535audio_dma_ops structures are never modified, so declare them as
const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
sound/pci/cs5535audio/cs5535audio_pcm.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/sound/pci/cs5535audio/cs5535audio_pcm.c b/sound/pci/cs5535audio/cs5535audio_pcm.c
index 9c2dc91..27fa57d 100644
--- a/sound/pci/cs5535audio/cs5535audio_pcm.c
+++ b/sound/pci/cs5535audio/cs5535audio_pcm.c
@@ -402,7 +402,7 @@ static struct snd_pcm_ops snd_cs5535audio_capture_ops = {
.pointer = snd_cs5535audio_pcm_pointer,
-static struct cs5535audio_dma_ops snd_cs5535audio_playback_dma_ops = {
+static const struct cs5535audio_dma_ops snd_cs5535audio_playback_dma_ops = {
.type = CS5535AUDIO_DMA_PLAYBACK,
.enable_dma = cs5535audio_playback_enable_dma,
.disable_dma = cs5535audio_playback_disable_dma,
@@ -412,7 +412,7 @@ static struct cs5535audio_dma_ops snd_cs5535audio_playback_dma_ops = {
.read_dma_pntr = cs5535audio_playback_read_dma_pntr,
-static struct cs5535audio_dma_ops snd_cs5535audio_capture_dma_ops = {
+static const struct cs5535audio_dma_ops snd_cs5535audio_capture_dma_ops = {
.type = CS5535AUDIO_DMA_CAPTURE,
.enable_dma = cs5535audio_capture_enable_dma,
.disable_dma = cs5535audio_capture_disable_dma, |
