ALSA: au1x00: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/mips/au1x00.c | 12 +++++++++---
 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/sound/mips/au1x00.c b/sound/mips/au1x00.c
index fbcaa54..1e30e84 100644
--- a/sound/mips/au1x00.c
+++ b/sound/mips/au1x00.c
@@ -633,19 +633,25 @@ static int au1000_ac97_probe(struct platform_device *pdev)
 	au1000->stream[PLAYBACK] = kmalloc(sizeof(struct audio_stream),
 					   GFP_KERNEL);
-	if (!au1000->stream[PLAYBACK])
+	if (!au1000->stream[PLAYBACK]) {
+		err = -ENOMEM;
 		goto out;
 	au1000->stream[PLAYBACK]->dma = -1;
 	au1000->stream[CAPTURE] = kmalloc(sizeof(struct audio_stream),
 					  GFP_KERNEL);
-	if (!au1000->stream[CAPTURE])
+	if (!au1000->stream[CAPTURE]) {
+		err = -ENOMEM;
 		goto out;
 	au1000->stream[CAPTURE]->dma = -1;
 	r = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!r)
+	if (!r) {
+		err = -ENODEV;
 		goto out;
 	err = -EBUSY;
 	au1000->ac97_res_port = request_mem_region(r->start, resource_size(r),
BtrLinux
Privacy Overview
