ALSA: asihpi – use kzalloc()
Author: Thomas Meyer <thomas@m3y3r.de>
 Use kzalloc rather than kmalloc followed by memset with 0
 This considers some simple cases that are common and easy to validate
 Note in particular that there are no ...s in the rule, so all of the
 matched code has to be contiguous
 The semantic patch that makes this output is available
 in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
 More information about semantic patching is available at
 http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
Signed-off-by: Takashi Iwai
 sound/pci/asihpi/hpicmn.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/sound/pci/asihpi/hpicmn.c b/sound/pci/asihpi/hpicmn.c
index 65b7ca1..bd47521 100644
--- a/sound/pci/asihpi/hpicmn.c
+++ b/sound/pci/asihpi/hpicmn.c
@@ -631,13 +631,12 @@ struct hpi_control_cache *hpi_alloc_control_cache(const u32 control_count,
 	if (!p_cache)
 		return NULL;
-	p_cache->p_info =
-		kmalloc(sizeof(*p_cache->p_info) * control_count, GFP_KERNEL);
+	p_cache->p_info = kzalloc(sizeof(*p_cache->p_info) * control_count,
+				  GFP_KERNEL);
 	if (!p_cache->p_info) {
 		kfree(p_cache);
 		return NULL;
-	memset(p_cache->p_info, 0, sizeof(*p_cache->p_info) * control_count);
 	p_cache->cache_size_in_bytes = size_in_bytes;
 	p_cache->control_count = control_count;
 	p_cache->p_cache = p_dsp_control_buffer;
BtrLinux
Privacy Overview
