ALSA: aoa: Delete an unnecessary check before the function call “snd_pcm_suspend_all”
Author: Markus Elfring <elfring@users.sourceforge.net>
The snd_pcm_suspend_all() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Takashi Iwai
sound/aoa/soundbus/i2sbus/core.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/sound/aoa/soundbus/i2sbus/core.c b/sound/aoa/soundbus/i2sbus/core.c
index 4e2b4fb..837ba99 100644
--- a/sound/aoa/soundbus/i2sbus/core.c
+++ b/sound/aoa/soundbus/i2sbus/core.c
@@ -381,10 +381,8 @@ static int i2sbus_suspend(struct macio_dev* dev, pm_message_t state)
list_for_each_entry(i2sdev, &control->list, item) {
/* Notify Alsa */
- if (i2sdev->sound.pcm) {
- /* Suspend PCM streams */
- snd_pcm_suspend_all(i2sdev->sound.pcm);
+ /* Suspend PCM streams */
+ snd_pcm_suspend_all(i2sdev->sound.pcm);
/* Notify codecs */
list_for_each_entry(cii, &i2sdev->sound.codec_list, list) { |
/* Notify Alsa */
/* Notify codecs */
