alpha: use BUG_ON where possible
Author: Sasha Levin <sasha.levin@oracle.com>
Just use BUG_ON() instead of constructions such as:
	if (...)
		BUG()
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression e;
- if (e) BUG();
+ BUG_ON(e);
Signed-off-by: Sasha Levin
Signed-off-by: Jiri Kosina
 arch/alpha/kernel/pci_iommu.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/arch/alpha/kernel/pci_iommu.c b/arch/alpha/kernel/pci_iommu.c
index 3f844d2..a21d0ab 100644
--- a/arch/alpha/kernel/pci_iommu.c
+++ b/arch/alpha/kernel/pci_iommu.c
@@ -354,8 +354,7 @@ static dma_addr_t alpha_pci_map_page(struct device *dev, struct page *page,
 	struct pci_dev *pdev = alpha_gendev_to_pci(dev);
 	int dac_allowed;
-	if (dir == PCI_DMA_NONE)
-		BUG();
+	BUG_ON(dir == PCI_DMA_NONE);
 	dac_allowed = pdev ? pci_dac_dma_supported(pdev, pdev->dma_mask) : 0;
 	return pci_map_single_1(pdev, (char *)page_address(page) + offset,
@@ -378,8 +377,7 @@ static void alpha_pci_unmap_page(struct device *dev, dma_addr_t dma_addr,
 	struct pci_iommu_arena *arena;
 	long dma_ofs, npages;
-		BUG();
 	if (dma_addr >= __direct_map_base
 	    && dma_addr < __direct_map_base + __direct_map_size) {
@@ -662,8 +660,7 @@ static int alpha_pci_map_sg(struct device *dev, struct scatterlist *sg,
 	dma_addr_t max_dma;
 	int dac_allowed;
-		BUG();
 	dac_allowed = dev ? pci_dac_dma_supported(pdev, pdev->dma_mask) : 0;
@@ -742,8 +739,7 @@ static void alpha_pci_unmap_sg(struct device *dev, struct scatterlist *sg,
 	dma_addr_t max_dma;
 	dma_addr_t fbeg, fend;
-		BUG();
 	if (! alpha_mv.mv_pci_tbi)
 		return;
BtrLinux
Privacy Overview
