alpha: Convert to new irq function names
Author: Thomas Gleixner <tglx@linutronix.de>
Scripted with coccinelle.
Signed-off-by: Thomas Gleixner
 arch/alpha/kernel/irq.c           |  2 +-
 arch/alpha/kernel/irq_alpha.c     |  2 +-
 arch/alpha/kernel/irq_i8259.c     |  2 +-
 arch/alpha/kernel/irq_pyxis.c     |  2 +-
 arch/alpha/kernel/irq_srm.c       |  2 +-
 arch/alpha/kernel/sys_alcor.c     |  2 +-
 arch/alpha/kernel/sys_cabriolet.c |  4 ++--
 arch/alpha/kernel/sys_dp264.c     |  2 +-
 arch/alpha/kernel/sys_eb64p.c     |  2 +-
 arch/alpha/kernel/sys_eiger.c     |  2 +-
 arch/alpha/kernel/sys_jensen.c    | 10 +++++-----
 arch/alpha/kernel/sys_marvel.c    |  8 ++++----
 arch/alpha/kernel/sys_mikasa.c    |  3 ++-
 arch/alpha/kernel/sys_noritake.c  |  3 ++-
 arch/alpha/kernel/sys_rawhide.c   |  3 ++-
 arch/alpha/kernel/sys_rx164.c     |  2 +-
 arch/alpha/kernel/sys_sable.c     |  4 ++--
 arch/alpha/kernel/sys_takara.c    |  3 ++-
 arch/alpha/kernel/sys_titan.c     |  2 +-
 arch/alpha/kernel/sys_wildfire.c  | 12 ++++++------
 20 files changed, 38 insertions(+), 34 deletions(-)
diff --git a/arch/alpha/kernel/irq.c b/arch/alpha/kernel/irq.c
index a19d600..1461d7c 100644
--- a/arch/alpha/kernel/irq.c
+++ b/arch/alpha/kernel/irq.c
@@ -102,7 +102,7 @@ show_interrupts(struct seq_file *p, void *v)
 		for_each_online_cpu(j)
 			seq_printf(p, "%10u ", kstat_irqs_cpu(irq, j));
 #endif
-		seq_printf(p, " %14s", get_irq_desc_chip(desc)->name);
+		seq_printf(p, " %14s", irq_desc_get_chip(desc)->name);
 		seq_printf(p, "  %c%s",
 			(action->flags & IRQF_DISABLED)?'+':' ',
 			action->name);
diff --git a/arch/alpha/kernel/irq_alpha.c b/arch/alpha/kernel/irq_alpha.c
index 411ca11..1479dc6 100644
--- a/arch/alpha/kernel/irq_alpha.c
+++ b/arch/alpha/kernel/irq_alpha.c
@@ -228,7 +228,7 @@ struct irqaction timer_irqaction = {
 void __init
 init_rtc_irq(void)
-	set_irq_chip_and_handler_name(RTC_IRQ, &no_irq_chip,
+	irq_set_chip_and_handler_name(RTC_IRQ, &no_irq_chip,
 				      handle_simple_irq, "RTC");
 	setup_irq(RTC_IRQ, &timer_irqaction);
diff --git a/arch/alpha/kernel/irq_i8259.c b/arch/alpha/kernel/irq_i8259.c
index c7cc981..e1861c7 100644
--- a/arch/alpha/kernel/irq_i8259.c
+++ b/arch/alpha/kernel/irq_i8259.c
@@ -92,7 +92,7 @@ init_i8259a_irqs(void)
 	outb(0xff, 0xA1);	/* mask all of 8259A-2 */
 	for (i = 0; i < 16; i++) {
-		set_irq_chip_and_handler(i, &i8259a_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &i8259a_irq_type, handle_level_irq);
 	setup_irq(2, &cascade);
diff --git a/arch/alpha/kernel/irq_pyxis.c b/arch/alpha/kernel/irq_pyxis.c
index b30227f..13c97a5 100644
--- a/arch/alpha/kernel/irq_pyxis.c
+++ b/arch/alpha/kernel/irq_pyxis.c
@@ -102,7 +102,7 @@ init_pyxis_irqs(unsigned long ignore_mask)
 	for (i = 16; i < 48; ++i) {
 		if ((ignore_mask >> i) & 1)
 			continue;
-		set_irq_chip_and_handler(i, &pyxis_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &pyxis_irq_type, handle_level_irq);
 		irq_set_status_flags(i, IRQ_LEVEL);
diff --git a/arch/alpha/kernel/irq_srm.c b/arch/alpha/kernel/irq_srm.c
index 82a47bb..a79fa30 100644
--- a/arch/alpha/kernel/irq_srm.c
+++ b/arch/alpha/kernel/irq_srm.c
@@ -51,7 +51,7 @@ init_srm_irqs(long max, unsigned long ignore_mask)
 	for (i = 16; i < max; ++i) {
 		if (i < 64 && ((ignore_mask >> i) & 1))
 			continue;
-		set_irq_chip_and_handler(i, &srm_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &srm_irq_type, handle_level_irq);
diff --git a/arch/alpha/kernel/sys_alcor.c b/arch/alpha/kernel/sys_alcor.c
index 88d95e8..0e14399 100644
--- a/arch/alpha/kernel/sys_alcor.c
+++ b/arch/alpha/kernel/sys_alcor.c
@@ -125,7 +125,7 @@ alcor_init_irq(void)
 		   on while IRQ probing.  */
 		if (i >= 16+20 && i <= 16+30)
 			continue;
-		set_irq_chip_and_handler(i, &alcor_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &alcor_irq_type, handle_level_irq);
 	i8259a_irq_type.irq_ack = alcor_isa_mask_and_ack_irq;
diff --git a/arch/alpha/kernel/sys_cabriolet.c b/arch/alpha/kernel/sys_cabriolet.c
index 57eb630..c8c112d 100644
--- a/arch/alpha/kernel/sys_cabriolet.c
+++ b/arch/alpha/kernel/sys_cabriolet.c
@@ -105,8 +105,8 @@ common_init_irq(void (*srm_dev_int)(unsigned long v))
 		outb(0xff, 0x806);
 		for (i = 16; i < 35; ++i) {
-			set_irq_chip_and_handler(i, &cabriolet_irq_type,
-				handle_level_irq);
+			irq_set_chip_and_handler(i, &cabriolet_irq_type,
+						 handle_level_irq);
diff --git a/arch/alpha/kernel/sys_dp264.c b/arch/alpha/kernel/sys_dp264.c
index 481df4e..5ac00fd 100644
--- a/arch/alpha/kernel/sys_dp264.c
+++ b/arch/alpha/kernel/sys_dp264.c
@@ -270,7 +270,7 @@ init_tsunami_irqs(struct irq_chip * ops, int imin, int imax)
 	long i;
 	for (i = imin; i <= imax; ++i) {
-		set_irq_chip_and_handler(i, ops, handle_level_irq);
+		irq_set_chip_and_handler(i, ops, handle_level_irq);
diff --git a/arch/alpha/kernel/sys_eb64p.c b/arch/alpha/kernel/sys_eb64p.c
index 402e908..a7a23b4 100644
--- a/arch/alpha/kernel/sys_eb64p.c
+++ b/arch/alpha/kernel/sys_eb64p.c
@@ -118,7 +118,7 @@ eb64p_init_irq(void)
 	init_i8259a_irqs();
 	for (i = 16; i < 32; ++i) {
-		set_irq_chip_and_handler(i, &eb64p_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &eb64p_irq_type, handle_level_irq);
diff --git a/arch/alpha/kernel/sys_eiger.c b/arch/alpha/kernel/sys_eiger.c
index 0b44a54..a60cd5b 100644
--- a/arch/alpha/kernel/sys_eiger.c
+++ b/arch/alpha/kernel/sys_eiger.c
@@ -138,7 +138,7 @@ eiger_init_irq(void)
 	init_i8259a_irqs();
 	for (i = 16; i < 128; ++i) {
-		set_irq_chip_and_handler(i, &eiger_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &eiger_irq_type, handle_level_irq);
diff --git a/arch/alpha/kernel/sys_jensen.c b/arch/alpha/kernel/sys_jensen.c
index 00341b7..7f1a87f1 100644
--- a/arch/alpha/kernel/sys_jensen.c
+++ b/arch/alpha/kernel/sys_jensen.c
@@ -171,11 +171,11 @@ jensen_init_irq(void)
 	init_i8259a_irqs();
-	set_irq_chip_and_handler(1, &jensen_local_irq_type, handle_level_irq);
-	set_irq_chip_and_handler(4, &jensen_local_irq_type, handle_level_irq);
-	set_irq_chip_and_handler(3, &jensen_local_irq_type, handle_level_irq);
-	set_irq_chip_and_handler(7, &jensen_local_irq_type, handle_level_irq);
-	set_irq_chip_and_handler(9, &jensen_local_irq_type, handle_level_irq);
+	irq_set_chip_and_handler(1, &jensen_local_irq_type, handle_level_irq);
+	irq_set_chip_and_handler(4, &jensen_local_irq_type, handle_level_irq);
+	irq_set_chip_and_handler(3, &jensen_local_irq_type, handle_level_irq);
+	irq_set_chip_and_handler(7, &jensen_local_irq_type, handle_level_irq);
+	irq_set_chip_and_handler(9, &jensen_local_irq_type, handle_level_irq);
 	common_init_isa_dma();
diff --git a/arch/alpha/kernel/sys_marvel.c b/arch/alpha/kernel/sys_marvel.c
index e619107..388b99d 100644
--- a/arch/alpha/kernel/sys_marvel.c
+++ b/arch/alpha/kernel/sys_marvel.c
@@ -276,7 +276,7 @@ init_io7_irqs(struct io7 *io7,
 	/* Set up the lsi irqs.  */
 	for (i = 0; i < 128; ++i) {
-		set_irq_chip_and_handler(base + i, lsi_ops, handle_level_irq);
+		irq_set_chip_and_handler(base + i, lsi_ops, handle_level_irq);
@@ -290,7 +290,7 @@ init_io7_irqs(struct io7 *io7,
 	/* Set up the msi irqs.  */
 	for (i = 128; i < (128 + 512); ++i) {
-		set_irq_chip_and_handler(base + i, msi_ops, handle_level_irq);
+		irq_set_chip_and_handler(base + i, msi_ops, handle_level_irq);
@@ -308,8 +308,8 @@ marvel_init_irq(void)
 	/* Reserve the legacy irqs.  */
 	for (i = 0; i < 16; ++i) {
-		set_irq_chip_and_handler(i, &marvel_legacy_irq_type,
+		irq_set_chip_and_handler(i, &marvel_legacy_irq_type,
 	/* Init the io7 irqs.  */
diff --git a/arch/alpha/kernel/sys_mikasa.c b/arch/alpha/kernel/sys_mikasa.c
index cf7f43d..0e6e469 100644
--- a/arch/alpha/kernel/sys_mikasa.c
+++ b/arch/alpha/kernel/sys_mikasa.c
@@ -98,7 +98,8 @@ mikasa_init_irq(void)
 	mikasa_update_irq_hw(0);
-		set_irq_chip_and_handler(i, &mikasa_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &mikasa_irq_type,
diff --git a/arch/alpha/kernel/sys_noritake.c b/arch/alpha/kernel/sys_noritake.c
index 92bc188..a00ac70 100644
--- a/arch/alpha/kernel/sys_noritake.c
+++ b/arch/alpha/kernel/sys_noritake.c
@@ -127,7 +127,8 @@ noritake_init_irq(void)
 	outw(0, 0x54c);
-		set_irq_chip_and_handler(i, &noritake_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &noritake_irq_type,
diff --git a/arch/alpha/kernel/sys_rawhide.c b/arch/alpha/kernel/sys_rawhide.c
index 936d414..7f52161 100644
--- a/arch/alpha/kernel/sys_rawhide.c
+++ b/arch/alpha/kernel/sys_rawhide.c
@@ -180,7 +180,8 @@ rawhide_init_irq(void)
-		set_irq_chip_and_handler(i, &rawhide_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &rawhide_irq_type,
diff --git a/arch/alpha/kernel/sys_rx164.c b/arch/alpha/kernel/sys_rx164.c
index cea22a6..216d94d 100644
--- a/arch/alpha/kernel/sys_rx164.c
+++ b/arch/alpha/kernel/sys_rx164.c
@@ -99,7 +99,7 @@ rx164_init_irq(void)
 	rx164_update_irq_hw(0);
 	for (i = 16; i < 40; ++i) {
-		set_irq_chip_and_handler(i, &rx164_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &rx164_irq_type, handle_level_irq);
diff --git a/arch/alpha/kernel/sys_sable.c b/arch/alpha/kernel/sys_sable.c
index a349538..da714e4 100644
--- a/arch/alpha/kernel/sys_sable.c
+++ b/arch/alpha/kernel/sys_sable.c
@@ -518,8 +518,8 @@ sable_lynx_init_irq(int nr_of_irqs)
 	long i;
 	for (i = 0; i < nr_of_irqs; ++i) {
-		set_irq_chip_and_handler(i, &sable_lynx_irq_type,
+		irq_set_chip_and_handler(i, &sable_lynx_irq_type,
diff --git a/arch/alpha/kernel/sys_takara.c b/arch/alpha/kernel/sys_takara.c
index 42a5331..a31f8cd 100644
--- a/arch/alpha/kernel/sys_takara.c
+++ b/arch/alpha/kernel/sys_takara.c
@@ -138,7 +138,8 @@ takara_init_irq(void)
 		takara_update_irq_hw(i, -1);
-		set_irq_chip_and_handler(i, &takara_irq_type, handle_level_irq);
+		irq_set_chip_and_handler(i, &takara_irq_type,
diff --git a/arch/alpha/kernel/sys_titan.c b/arch/alpha/kernel/sys_titan.c
index 8c13a0c..fea0e46 100644
--- a/arch/alpha/kernel/sys_titan.c
+++ b/arch/alpha/kernel/sys_titan.c
@@ -179,7 +179,7 @@ init_titan_irqs(struct irq_chip * ops, int imin, int imax)
 	long i;
diff --git a/arch/alpha/kernel/sys_wildfire.c b/arch/alpha/kernel/sys_wildfire.c
index ca60a38..d3cb28b 100644
--- a/arch/alpha/kernel/sys_wildfire.c
+++ b/arch/alpha/kernel/sys_wildfire.c
@@ -183,17 +183,17 @@ wildfire_init_irq_per_pca(int qbbno, int pcano)
 		if (i == 2)
 			continue;
-		set_irq_chip_and_handler(i+irq_bias, &wildfire_irq_type,
+		irq_set_chip_and_handler(i + irq_bias, &wildfire_irq_type,
 		irq_set_status_flags(i + irq_bias, IRQ_LEVEL);
-	set_irq_chip_and_handler(36+irq_bias, &wildfire_irq_type,
+	irq_set_chip_and_handler(36 + irq_bias, &wildfire_irq_type,
 	irq_set_status_flags(36 + irq_bias, IRQ_LEVEL);
 	for (i = 40; i < 64; ++i) {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
