airo_cs: Remove typedef local_info_t
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
local_info_t. Also, the name of the struct is changed to drop the _t,
to make the name look less typedef-like.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/wireless/airo_cs.c | 25 +++++++++++++------------
1 file changed, 13 insertions(+), 12 deletions(-)
diff --git a/drivers/net/wireless/airo_cs.c b/drivers/net/wireless/airo_cs.c
index 7e9ede6..d9ed22b 100644
--- a/drivers/net/wireless/airo_cs.c
+++ b/drivers/net/wireless/airo_cs.c
@@ -56,18 +56,18 @@ static void airo_release(struct pcmcia_device *link);
static void airo_detach(struct pcmcia_device *p_dev);
-typedef struct local_info_t {
+struct local_info {
struct net_device *eth_dev;
-} local_info_t;
static int airo_probe(struct pcmcia_device *p_dev)
- local_info_t *local;
+ struct local_info *local;
dev_dbg(&p_dev->dev, "airo_attach()\n");
/* Allocate space for private device-specific data */
- local = kzalloc(sizeof(local_info_t), GFP_KERNEL);
+ local = kzalloc(sizeof(*local), GFP_KERNEL);
if (!local)
return -ENOMEM;
@@ -82,10 +82,11 @@ static void airo_detach(struct pcmcia_device *link)
airo_release(link);
- if (((local_info_t *)link->priv)->eth_dev) {
- stop_airo_card(((local_info_t *)link->priv)->eth_dev, 0);
+ if (((struct local_info *)link->priv)->eth_dev) {
+ stop_airo_card(((struct local_info *)link->priv)->eth_dev,
+ 0);
- ((local_info_t *)link->priv)->eth_dev = NULL;
+ ((struct local_info *)link->priv)->eth_dev = NULL;
kfree(link->priv);
} /* airo_detach */
@@ -101,7 +102,7 @@ static int airo_cs_config_check(struct pcmcia_device *p_dev, void *priv_data)
static int airo_config(struct pcmcia_device *link)
- local_info_t *dev;
+ struct local_info *dev;
int ret;
dev = link->priv;
@@ -121,10 +122,10 @@ static int airo_config(struct pcmcia_device *link)
ret = pcmcia_enable_device(link);
if (ret)
goto failed;
init_airo_card(link->irq,
link->resource[0]->start, 1, &link->dev);
- if (!((local_info_t *)link->priv)->eth_dev)
+ if (!((struct local_info *)link->priv)->eth_dev)
goto failed;
return 0;
@@ -142,7 +143,7 @@ static void airo_release(struct pcmcia_device *link)
static int airo_suspend(struct pcmcia_device *link)
- local_info_t *local = link->priv;
+ struct local_info *local = link->priv;
netif_device_detach(local->eth_dev);
@@ -151,7 +152,7 @@ static int airo_suspend(struct pcmcia_device *link)
static int airo_resume(struct pcmcia_device *link)
if (link->open) {
reset_airo_card(local->eth_dev); |
-} local_info_t;
if (!local)
return -ENOMEM;
airo_release(link);
+ 0);
kfree(link->priv);
} /* airo_detach */
int ret;
dev = link->priv;
if (ret)
goto failed;
goto failed;
return 0;
if (link->open) {
