ah6: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Acked-by: Herbert Xu
Signed-off-by: David S. Miller
 net/ipv6/ah6.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/net/ipv6/ah6.c b/net/ipv6/ah6.c
index ed7d4e3f..0630a4d5 100644
--- a/net/ipv6/ah6.c
+++ b/net/ipv6/ah6.c
@@ -577,8 +577,10 @@ static int ah6_input(struct xfrm_state *x, struct sk_buff *skb)
 	work_iph = ah_alloc_tmp(ahash, nfrags + sglists, hdr_len +
 				ahp->icv_trunc_len + seqhi_len);
-	if (!work_iph)
+	if (!work_iph) {
+		err = -ENOMEM;
 		goto out;
 	auth_data = ah_tmp_auth((u8 *)work_iph, hdr_len);
 	seqhi = (__be32 *)(auth_data + ahp->icv_trunc_len);
BtrLinux
Privacy Overview
