Author: Márton Németh <nm127@freemail.hu>
The ids field of the struct acpi_driver is constant in
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Len Brown
drivers/acpi/pci_link.c | 2 +-
drivers/acpi/pci_root.c | 2 +-
drivers/acpi/power.c | 2 +-
drivers/acpi/power_meter.c | 2 +-
4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/acpi/pci_link.c b/drivers/acpi/pci_link.c
index 394ae89..04b0f00 100644
--- a/drivers/acpi/pci_link.c
+++ b/drivers/acpi/pci_link.c
@@ -56,7 +56,7 @@ ACPI_MODULE_NAME("pci_link");
static int acpi_pci_link_add(struct acpi_device *device);
static int acpi_pci_link_remove(struct acpi_device *device, int type);
-static struct acpi_device_id link_device_ids[] = {
+static const struct acpi_device_id link_device_ids[] = {
{"PNP0C0F", 0},
{"", 0},
diff --git a/drivers/acpi/pci_root.c b/drivers/acpi/pci_root.c
index 101cce3..64f55b6 100644
--- a/drivers/acpi/pci_root.c
+++ b/drivers/acpi/pci_root.c
@@ -46,7 +46,7 @@ static int acpi_pci_root_add(struct acpi_device *device);
static int acpi_pci_root_remove(struct acpi_device *device, int type);
static int acpi_pci_root_start(struct acpi_device *device);
-static struct acpi_device_id root_device_ids[] = {
+static const struct acpi_device_id root_device_ids[] = {
{"PNP0A03", 0},
{"", 0},
diff --git a/drivers/acpi/power.c b/drivers/acpi/power.c
index 22b2979..0f30c3c 100644
--- a/drivers/acpi/power.c
+++ b/drivers/acpi/power.c
@@ -65,7 +65,7 @@ static int acpi_power_remove(struct acpi_device *device, int type);
static int acpi_power_resume(struct acpi_device *device);
static int acpi_power_open_fs(struct inode *inode, struct file *file);
-static struct acpi_device_id power_device_ids[] = {
+static const struct acpi_device_id power_device_ids[] = {
{ACPI_POWER_HID, 0},
{"", 0},
diff --git a/drivers/acpi/power_meter.c b/drivers/acpi/power_meter.c
index 2ef7030..ca75c36 100644
--- a/drivers/acpi/power_meter.c
+++ b/drivers/acpi/power_meter.c
@@ -64,7 +64,7 @@ static int can_cap_in_hardware(void)
return force_cap_on || cap_in_hardware;
-static struct acpi_device_id power_meter_ids[] = {
+static const struct acpi_device_id power_meter_ids[] = {
{"ACPI000D", 0},
{"", 0},
{"PNP0C0F", 0},
{"", 0},
{"PNP0A03", 0},
{"", 0},
{"", 0},
{"ACPI000D", 0},
{"", 0},
