ACPI: drivers/acpi: elide a non-zero test on a result that is never 0
The function thermal_cooling_device_register always returns either a valid
pointer or a value made with ERR_PTR, so a test for non-zero on the result
will always succeed.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
@a@
expression E, E1;
statement S,S1;
position p;
E = thermal_cooling_device_register(...)
... when != E = E1
if@p (E) S else S1
@n@
position a.p;
expression E,E1;
statement S,S1;
E = NULL
... when != E = E1
if@p (E) S else S1
@depends on !n@
expression E;
statement S,S1;
position a.p;
* if@p (E)
  S else S1
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Len Brown
 drivers/acpi/fan.c            | 34 ++++++++++++++++------------------
 drivers/acpi/processor_core.c | 30 ++++++++++++++----------------
 drivers/acpi/video.c          | 28 +++++++++++++---------------
 3 files changed, 43 insertions(+), 49 deletions(-)
diff --git a/drivers/acpi/fan.c b/drivers/acpi/fan.c
index c8e3cba..4d535c5 100644
--- a/drivers/acpi/fan.c
+++ b/drivers/acpi/fan.c
@@ -260,24 +260,22 @@ static int acpi_fan_add(struct acpi_device *device)
 		result = PTR_ERR(cdev);
 		goto end;
-	if (cdev) {
-		printk(KERN_INFO PREFIX
-			"%s is registered as cooling_device%d\n",
-			device->dev.bus_id, cdev->id);
-		acpi_driver_data(device) = cdev;
-		result = sysfs_create_link(&device->dev.kobj,
-					   &cdev->device.kobj,
-					   "thermal_cooling");
-		if (result)
-			return result;
-		result = sysfs_create_link(&cdev->device.kobj,
-					   &device->dev.kobj,
-					   "device");
-		if (result)
-			return result;
+	printk(KERN_INFO PREFIX
+		"%s is registered as cooling_device%d\n",
+		device->dev.bus_id, cdev->id);
+	acpi_driver_data(device) = cdev;
+	result = sysfs_create_link(&device->dev.kobj,
+				   &cdev->device.kobj,
+				   "thermal_cooling");
+	if (result)
+		return result;
+	result = sysfs_create_link(&cdev->device.kobj,
+				   &device->dev.kobj,
+				   "device");
+	if (result)
+		return result;
 	result = acpi_fan_add_fs(device);
 	if (result)
diff --git a/drivers/acpi/processor_core.c b/drivers/acpi/processor_core.c
index 36a68fa..3a136f6 100644
--- a/drivers/acpi/processor_core.c
+++ b/drivers/acpi/processor_core.c
@@ -674,22 +674,20 @@ static int __cpuinit acpi_processor_start(struct acpi_device *device)
 		result = PTR_ERR(pr->cdev);
 		goto end;
-	if (pr->cdev) {
-			device->dev.bus_id, pr->cdev->id);
-					   &pr->cdev->device.kobj,
-		if (result)
-			return result;
-		result = sysfs_create_link(&pr->cdev->device.kobj,
-					   "device");
-		if (result)
-			return result;
+		device->dev.bus_id, pr->cdev->id);
+				   &pr->cdev->device.kobj,
+	if (result)
+		return result;
+	result = sysfs_create_link(&pr->cdev->device.kobj,
+				   "device");
+	if (result)
+		return result;
 	if (pr->flags.throttling) {
 		printk(KERN_INFO PREFIX "%s [%s] (supports",
diff --git a/drivers/acpi/video.c b/drivers/acpi/video.c
index 12fb44f..fe09b57 100644
--- a/drivers/acpi/video.c
+++ b/drivers/acpi/video.c
@@ -734,21 +734,19 @@ static void acpi_video_device_find_cap(struct acpi_video_device *device)
 		if (IS_ERR(device->cdev))
 			return;
-		if (device->cdev) {
-				device->dev->dev.bus_id, device->cdev->id);
-			result = sysfs_create_link(&device->dev->dev.kobj,
-					  &device->cdev->device.kobj,
-			if (result)
-				printk(KERN_ERR PREFIX "Create sysfs link\n");
-			result = sysfs_create_link(&device->cdev->device.kobj,
-					  &device->dev->dev.kobj,
-					  "device");
-                        if (result)
+			device->dev->dev.bus_id, device->cdev->id);
+		result = sysfs_create_link(&device->dev->dev.kobj,
+				  &device->cdev->device.kobj,
+		if (result)
+			printk(KERN_ERR PREFIX "Create sysfs link\n");
+		result = sysfs_create_link(&device->cdev->device.kobj,
+				  &device->dev->dev.kobj,
+				  "device");
+		if (result)
 	if (device->cap._DCS && device->cap._DSS){
 		static int count = 0;
BtrLinux
Privacy Overview
