ab8500_charger: Fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize return variable before exiting on an error path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Anton Vorontsov
 drivers/power/ab8500_charger.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/power/ab8500_charger.c b/drivers/power/ab8500_charger.c
index d4f0c98..c2ef947 100644
--- a/drivers/power/ab8500_charger.c
+++ b/drivers/power/ab8500_charger.c
@@ -2614,6 +2614,7 @@ static int __devinit ab8500_charger_probe(struct platform_device *pdev)
 		create_singlethread_workqueue("ab8500_charger_wq");
 	if (di->charger_wq == NULL) {
 		dev_err(di->dev, "failed to create work queue\n");
+		ret = -ENOMEM;
 		goto free_device_info;
BtrLinux
Privacy Overview
