mtd: spear_smi: failure test for null rather than negative integer
dev_get_platdata returns a pointer, so the failure value would be NULL
rather than a negative integer.
The semantic match that finds this problem is: (http://coccinelle.lip6.fr/)
expression x,e;
statement S1,S2;
*x = dev_get_platdata(...)
... when != x = e
*if (x < 0) S1 else S2
Signed-off-by: Julia Lawall
Acked-by: Stefan Roese
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
drivers/mtd/devices/spear_smi.c | 2 +-
diff --git a/drivers/mtd/devices/spear_smi.c b/drivers/mtd/devices/spear_smi.c
index b85f183..7c10466 100644
--- a/drivers/mtd/devices/spear_smi.c
+++ b/drivers/mtd/devices/spear_smi.c
@@ -935,7 +935,7 @@ static int __devinit spear_smi_probe(struct platform_device *pdev)
} else {
pdata = dev_get_platdata(&pdev->dev);
- if (pdata < 0) {
+ if (!pdata) {
ret = -ENODEV;
dev_err(&pdev->dev, "no platform data\n");
goto err; |
} else {
- if (pdata < 0) {
+ if (!pdata) {
ret = -ENODEV;
goto err;
