RDMA/nes: Use WARN()
Use WARN() rather than printk() followed by WARN_ON(1), for conciseness.
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression list es;
-printk(
+WARN(1,
  es);
-WARN_ON(1);
Signed-off-by: Julia Lawall
[ Remove extra KERN_ERR from WARN() format.  - Roland ]
Signed-off-by: Roland Dreier
 drivers/infiniband/hw/nes/nes_cm.c  | 8 +++-----
 drivers/infiniband/hw/nes/nes_mgt.c | 6 ++----
 2 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/infiniband/hw/nes/nes_cm.c b/drivers/infiniband/hw/nes/nes_cm.c
index cfaacaf..feb41e7 100644
--- a/drivers/infiniband/hw/nes/nes_cm.c
+++ b/drivers/infiniband/hw/nes/nes_cm.c
@@ -629,11 +629,9 @@ static void build_rdma0_msg(struct nes_cm_node *cm_node, struct nes_qp **nesqp_a
 	case SEND_RDMA_READ_ZERO:
 	default:
-		if (cm_node->send_rdma0_op != SEND_RDMA_READ_ZERO) {
-			printk(KERN_ERR "%s[%u]: Unsupported RDMA0 len operation=%u\n",
-				 __func__, __LINE__, cm_node->send_rdma0_op);
-			WARN_ON(1);
+		if (cm_node->send_rdma0_op != SEND_RDMA_READ_ZERO)
+			WARN(1, "Unsupported RDMA0 len operation=%u\n",
+			     cm_node->send_rdma0_op);
 		nes_debug(NES_DBG_CM, "Sending first rdma operation.\n");
 		wqe->wqe_words[NES_IWARP_SQ_WQE_MISC_IDX] =
 			cpu_to_le32(NES_IWARP_SQ_OP_RDMAR);
diff --git a/drivers/infiniband/hw/nes/nes_mgt.c b/drivers/infiniband/hw/nes/nes_mgt.c
index 4d6d77f..4166452 100644
--- a/drivers/infiniband/hw/nes/nes_mgt.c
+++ b/drivers/infiniband/hw/nes/nes_mgt.c
@@ -649,11 +649,9 @@ static void nes_chg_qh_handler(struct nes_device *nesdev, struct nes_cqp_request
 	nesqp = qh_chg->nesqp;
 	/* Should we handle the bad completion */
-	if (cqp_request->major_code) {
-		printk(KERN_ERR PFX "Invalid cqp_request major_code=0x%x\n",
+	if (cqp_request->major_code)
+		WARN(1, PFX "Invalid cqp_request major_code=0x%x\n",
 		       cqp_request->major_code);
-		WARN_ON(1);
 	switch (nesqp->pau_state) {
 	case PAU_DEL_QH:
BtrLinux
Privacy Overview
