[media] au0828: Replace memcpy with struct assignment
Author: Ezequiel Garcia <elezegarcia@gmail.com>
This kind of memcpy() is error-prone. Its replacement with a struct
assignment is prefered because it's type-safe and much easier to read.
Found by coccinelle. Hand patched and reviewed.
Tested by compilation only.
identifier struct_name;
struct struct_name to;
struct struct_name from;
expression E;
-memcpy(&(to), &(from), E);
+to = from;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Ezequiel Garcia
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/au0828/au0828-cards.c | 2 +-
 drivers/media/usb/au0828/au0828-i2c.c   | 9 +++------
 2 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/drivers/media/usb/au0828/au0828-cards.c b/drivers/media/usb/au0828/au0828-cards.c
index 88e35df..dd32dec 100644
--- a/drivers/media/usb/au0828/au0828-cards.c
+++ b/drivers/media/usb/au0828/au0828-cards.c
@@ -193,7 +193,7 @@ void au0828_card_setup(struct au0828_dev *dev)
 	dprintk(1, "%s()\n", __func__);
-	memcpy(&dev->board, &au0828_boards[dev->boardnr], sizeof(dev->board));
+	dev->board = au0828_boards[dev->boardnr];
 	if (dev->i2c_rc == 0) {
 		dev->i2c_client.addr = 0xa0 >> 1;
diff --git a/drivers/media/usb/au0828/au0828-i2c.c b/drivers/media/usb/au0828/au0828-i2c.c
index 20d69b5..17ec365 100644
--- a/drivers/media/usb/au0828/au0828-i2c.c
+++ b/drivers/media/usb/au0828/au0828-i2c.c
@@ -364,12 +364,9 @@ int au0828_i2c_register(struct au0828_dev *dev)
-	memcpy(&dev->i2c_adap, &au0828_i2c_adap_template,
-	       sizeof(dev->i2c_adap));
-	memcpy(&dev->i2c_algo, &au0828_i2c_algo_template,
-	       sizeof(dev->i2c_algo));
-	memcpy(&dev->i2c_client, &au0828_i2c_client_template,
-	       sizeof(dev->i2c_client));
+	dev->i2c_adap = au0828_i2c_adap_template;
+	dev->i2c_algo = au0828_i2c_algo_template;
+	dev->i2c_client = au0828_i2c_client_template;
 	dev->i2c_adap.dev.parent = &dev->usbdev->dev;
BtrLinux
Privacy Overview
