mtd: nand: davinci: use devm_ioremap_resource()
Author: Laurent Navet <laurent.navet@gmail.com>
Replace a call to deprecated devm_request_and_ioremap by devm_ioremap_resource.
Found with coccicheck and this semantic patch:
 scripts/coccinelle/api/devm_request_and_ioremap.cocci.
Signed-off-by: Laurent Navet
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
 drivers/mtd/nand/davinci_nand.c | 13 ++++++++-----
 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c
index c3e15a5..999ad9c 100644
--- a/drivers/mtd/nand/davinci_nand.c
+++ b/drivers/mtd/nand/davinci_nand.c
@@ -623,11 +623,14 @@ static int __init nand_davinci_probe(struct platform_device *pdev)
 		goto err_nomem;
-	vaddr = devm_request_and_ioremap(&pdev->dev, res1);
-	base = devm_request_and_ioremap(&pdev->dev, res2);
-	if (!vaddr || !base) {
-		dev_err(&pdev->dev, "ioremap failed\n");
-		ret = -EADDRNOTAVAIL;
+	vaddr = devm_ioremap_resource(&pdev->dev, res1);
+	if (IS_ERR(vaddr)) {
+		ret = PTR_ERR(vaddr);
+		goto err_ioremap;
+	base = devm_ioremap_resource(&pdev->dev, res2);
+	if (IS_ERR(base)) {
+		ret = PTR_ERR(base);
 		goto err_ioremap;
BtrLinux
Privacy Overview
