usb: musb: dsps: fix devm_ioremap_resource error detection code
devm_ioremap_resource returns an ERR_PTR value, not NULL, on failure.
Furthermore, the value returned by devm_ioremap_resource should be tested.
expression e,e1;
statement S;
*e = devm_ioremap_resource(...);
if (!e1) S
Signed-off-by: Julia Lawall
Signed-off-by: Felipe Balbi
drivers/usb/musb/musb_dsps.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/musb/musb_dsps.c b/drivers/usb/musb/musb_dsps.c
index 4ffbaac..4ad52e7 100644
--- a/drivers/usb/musb/musb_dsps.c
+++ b/drivers/usb/musb/musb_dsps.c
@@ -361,8 +361,8 @@ static int dsps_musb_init(struct musb *musb)
return -EINVAL;
reg_base = devm_ioremap_resource(dev, r);
- if (!musb->ctrl_base)
- return -EINVAL;
+ if (IS_ERR(reg_base))
+ return PTR_ERR(reg_base);
musb->ctrl_base = reg_base;
/* NOP driver needs change if supporting dual instance */ |
return -EINVAL;
- return -EINVAL;
