watchdog: nuc900_wdt.c: simplify use of devm_ioremap_resource
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
A simplified version of the semantic patch that makes this change is as
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Reviewed-by: Guenter Roeck
Acked-by: Wan Zongshun
Signed-off-by: Wim Van Sebroeck
 drivers/watchdog/nuc900_wdt.c | 5 -----
 1 file changed, 5 deletions(-)
diff --git a/drivers/watchdog/nuc900_wdt.c b/drivers/watchdog/nuc900_wdt.c
index e2b6d2c..b15b6ef 100644
--- a/drivers/watchdog/nuc900_wdt.c
+++ b/drivers/watchdog/nuc900_wdt.c
@@ -256,11 +256,6 @@ static int nuc900wdt_probe(struct platform_device *pdev)
 	spin_lock_init(&nuc900_wdt->wdt_lock);
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-		dev_err(&pdev->dev, "no memory resource specified\n");
-		return -ENOENT;
 	nuc900_wdt->wdt_base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(nuc900_wdt->wdt_base))
 		return PTR_ERR(nuc900_wdt->wdt_base);
BtrLinux
Privacy Overview
