staging: rtl8188eu: do not use comparisons on bool tests
Author: Valentina Manea <valentina.manea.m@gmail.com>
This patch fixes coccinelle errors regarding comparisons
used in bool tests.
Signed-off-by: Valentina Manea
Reviewed-by: Rusty Russell
 drivers/staging/rtl8188eu/core/rtw_pwrctrl.c   | 2 +-
 drivers/staging/rtl8188eu/hal/HalPhyRf_8188e.c | 6 +++---
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_pwrctrl.c b/drivers/staging/rtl8188eu/core/rtw_pwrctrl.c
index 58a1661..b45461f 100644
--- a/drivers/staging/rtl8188eu/core/rtw_pwrctrl.c
+++ b/drivers/staging/rtl8188eu/core/rtw_pwrctrl.c
@@ -193,7 +193,7 @@ void rtw_ps_processor(struct adapter *padapter)
 	if (pwrpriv->ips_mode_req == IPS_NONE)
 		goto exit;
-	if (rtw_pwr_unassociated_idle(padapter) == false)
+	if (!rtw_pwr_unassociated_idle(padapter))
 		goto exit;
 	if ((pwrpriv->rf_pwrstate == rf_on) && ((pwrpriv->pwr_state_check_cnts%4) == 0)) {
diff --git a/drivers/staging/rtl8188eu/hal/HalPhyRf_8188e.c b/drivers/staging/rtl8188eu/hal/HalPhyRf_8188e.c
index bb43793..8a7947d 100644
--- a/drivers/staging/rtl8188eu/hal/HalPhyRf_8188e.c
+++ b/drivers/staging/rtl8188eu/hal/HalPhyRf_8188e.c
@@ -819,7 +819,7 @@ void _PHY_SaveADDARegisters(struct adapter *adapt, u32 *ADDAReg, u32 *ADDABackup
 	struct hal_data_8188e	*pHalData = GET_HAL_DATA(adapt);
 	struct odm_dm_struct *dm_odm = &pHalData->odmpriv;
-	if (ODM_CheckPowerStatus(adapt) == false)
+	if (!ODM_CheckPowerStatus(adapt))
 		return;
 	ODM_RT_TRACE(dm_odm, ODM_COMP_CALIBRATION, ODM_DBG_LOUD, ("Save ADDA parameters.\n"));
@@ -888,7 +888,7 @@ _PHY_PathADDAOn(
 	ODM_RT_TRACE(dm_odm, ODM_COMP_CALIBRATION, ODM_DBG_LOUD, ("ADDA ON.\n"));
 	pathOn = isPathAOn ? 0x04db25a4 : 0x0b1b25a4;
-	if (false == is2t) {
+	if (!is2t) {
 		pathOn = 0x0bdb25a0;
 		ODM_SetBBReg(dm_odm, ADDAReg[0], bMaskDWord, 0x0b1b25a0);
 	} else {
@@ -1296,7 +1296,7 @@ void PHY_IQCalibrate_8188E(struct adapter *adapt, bool recovery)
 	bool is2t;
 	is2t = (dm_odm->RFType == ODM_2T2R) ? true : false;
 		return;
 	if (!(dm_odm->SupportAbility & ODM_RF_CALIBRATION))
