staging: rtl8187se: fix code allignment
Author: Teodora Baluta <teobaluta@gmail.com>
Fix confusingly indented code after if. This patch fixes the following
coccinelle issues:
drivers/staging/rtl8187se/r8180_wx.c:1148:2-11: code aligned with following code on line 1150
drivers/staging/rtl8187se/r8180_dm.c:668:1-84: code aligned with following code on line 674
drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c:623:2-38: code aligned with following code on line 625
drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c:148:1-85: code aligned with following code on line 149
Signed-off-by: Teodora Baluta
Reviewed-by: Rusty Russell
 drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c | 5 +++--
 drivers/staging/rtl8187se/r8180_dm.c               | 2 +-
 drivers/staging/rtl8187se/r8180_wx.c               | 8 ++++----
 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c b/drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c
index e014f7e..24d39cc 100644
--- a/drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c
+++ b/drivers/staging/rtl8187se/ieee80211/ieee80211_wx.c
@@ -145,7 +145,8 @@ static inline char *rtl818x_translate_scan(struct ieee80211_device *ieee,
 	/* Add quality statistics */
 	/* TODO: Fix these values... */
 	if (network->stats.signal == 0 || network->stats.rssi == 0)
-	printk("========>signal:%d, rssi:%d\n", network->stats.signal, network->stats.rssi);
+		printk("========>signal:%d, rssi:%d\n", network->stats.signal,
+		       network->stats.rssi);
 	iwe.cmd = IWEVQUAL;
 //	printk("SIGNAL: %d,RSSI: %d,NOISE: %d\n",network->stats.signal,network->stats.rssi,network->stats.noise);
 	iwe.u.qual.qual = network->stats.signalstrength;
@@ -622,7 +623,7 @@ done:
 	if (ieee->set_security)
 		ieee->set_security(ieee->dev, &sec);
-	 if (ieee->reset_on_keychange &&
+	if (ieee->reset_on_keychange &&
 	    ieee->iw_mode != IW_MODE_INFRA &&
 	    ieee->reset_port && ieee->reset_port(dev)) {
 		IEEE80211_DEBUG_WX("%s: reset_port failed\n", dev->name);
diff --git a/drivers/staging/rtl8187se/r8180_dm.c b/drivers/staging/rtl8187se/r8180_dm.c
index 980bafd..2ccd2cb 100644
--- a/drivers/staging/rtl8187se/r8180_dm.c
+++ b/drivers/staging/rtl8187se/r8180_dm.c
@@ -665,7 +665,7 @@ static void StaRateAdaptive87SE(struct net_device *dev)
 	if (bTryUp && bTryDown)
-	printk("StaRateAdaptive87B(): Tx Rate tried upping and downing simultaneously!\n");
+		printk("StaRateAdaptive87B(): Tx Rate tried upping and downing simultaneously!\n");
 	/* 1 Test Upgrading Tx Rate
 	 * Sometimes the cause of the low throughput (high retry rate) is the compatibility between the AP and NIC.
diff --git a/drivers/staging/rtl8187se/r8180_wx.c b/drivers/staging/rtl8187se/r8180_wx.c
index 098e368..4e01653 100644
--- a/drivers/staging/rtl8187se/r8180_wx.c
+++ b/drivers/staging/rtl8187se/r8180_wx.c
@@ -1147,12 +1147,12 @@ static int r8180_wx_set_gen_ie(struct net_device *dev,
 	if (priv->ieee80211->bHwRadioOff)
 		return 0;
-		down(&priv->wx_sem);
+	down(&priv->wx_sem);
 #if 1
-		ret = ieee80211_wx_set_gen_ie(priv->ieee80211, extra, wrqu->data.length);
+	ret = ieee80211_wx_set_gen_ie(priv->ieee80211, extra, wrqu->data.length);
 #endif
-		up(&priv->wx_sem);
-		return ret;
+	up(&priv->wx_sem);
+	return ret;
BtrLinux
Privacy Overview
