hamradio: 6pack: fix error return code
Set the return variable to an error code as done elsewhere in the function.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
 drivers/net/hamradio/6pack.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/hamradio/6pack.c b/drivers/net/hamradio/6pack.c
index 1450e33..66e2b19 100644
--- a/drivers/net/hamradio/6pack.c
+++ b/drivers/net/hamradio/6pack.c
@@ -662,7 +662,8 @@ static int sixpack_open(struct tty_struct *tty)
 	tty->receive_room = 65536;
 	/* Now we're ready to register. */
-	if (register_netdev(dev))
+	err = register_netdev(dev);
+	if (err)
 		goto out_free;
 	tnc_init(sp);
BtrLinux
