HID: sony: fix error return code
Currently the return variable ret is always 0.  Set it to other values in
error cases, as used in the direct return.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Jiri Kosina
 drivers/hid/hid-sony.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/hid/hid-sony.c b/drivers/hid/hid-sony.c
index b60bc389..f57ab5e 100644
--- a/drivers/hid/hid-sony.c
+++ b/drivers/hid/hid-sony.c
@@ -585,6 +585,7 @@ static int sony_leds_init(struct hid_device *hdev)
 		led = kzalloc(sizeof(struct led_classdev) + name_sz, GFP_KERNEL);
 		if (!led) {
 			hid_err(hdev, "Couldn't allocate memory for LED %d\n", n);
+			ret = -ENOMEM;
 			goto error_leds;
@@ -596,7 +597,8 @@ static int sony_leds_init(struct hid_device *hdev)
 		led->brightness_get = sony_led_get_brightness;
 		led->brightness_set = sony_led_set_brightness;
-		if (led_classdev_register(&hdev->dev, led)) {
+		ret = led_classdev_register(&hdev->dev, led);
+		if (ret) {
 			hid_err(hdev, "Failed to register LED %d\n", n);
 			kfree(led);
 			goto error_leds;
BtrLinux
