[media] ec168: fix error return code
The rest of the function uses ret to store the return value, even setting
ret to i a few lines before this, so return ret instead of i.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Cc: Antti Palosaari
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/dvb-usb-v2/ec168.c | 2 +-
diff --git a/drivers/media/usb/dvb-usb-v2/ec168.c b/drivers/media/usb/dvb-usb-v2/ec168.c
index 5c68f39..0c2b377 100644
--- a/drivers/media/usb/dvb-usb-v2/ec168.c
+++ b/drivers/media/usb/dvb-usb-v2/ec168.c
@@ -170,7 +170,7 @@ static int ec168_i2c_xfer(struct i2c_adapter *adap, struct i2c_msg msg[],
 error:
 	mutex_unlock(&d->i2c_mutex);
-	return i;
+	return ret;
 static u32 ec168_i2c_func(struct i2c_adapter *adapter)
BtrLinux
