ksz884x: delete useless variable
Delete a variable that is at most only assigned to a constant, but never
used otherwise. In this code, it is the variable result that is used for
the return code, not rc.
A simplified version of the semantic patch that fixes this problem is as
type T;
identifier i;
constant c;
-T i;
<... when != i
-i = c;
Signed-off-by: Julia Lawall
drivers/net/ethernet/micrel/ksz884x.c | 3 ---
1 file changed, 3 deletions(-)
diff --git a/drivers/net/ethernet/micrel/ksz884x.c b/drivers/net/ethernet/micrel/ksz884x.c
index 8e9dad7..ce84dc2 100644
--- a/drivers/net/ethernet/micrel/ksz884x.c
+++ b/drivers/net/ethernet/micrel/ksz884x.c
@@ -5853,15 +5853,12 @@ static int netdev_ioctl(struct net_device *dev, struct ifreq *ifr, int cmd)
struct dev_info *hw_priv = priv->adapter;
struct ksz_hw *hw = &hw_priv->hw;
struct ksz_port *port = &priv->port;
- int rc;
int result = 0;
struct mii_ioctl_data *data = if_mii(ifr);
if (down_interruptible(&priv->proc_sem))
return -ERESTARTSYS;
- /* assume success */
- rc = 0;
switch (cmd) {
/* Get address of MII PHY in use. */
case SIOCGMIIPHY: |
- int rc;
int result = 0;
- rc = 0;
switch (cmd) {
case SIOCGMIIPHY:
