altera: Remove casts of pointer to same type
Author: Joe Perches <joe@perches.com>
Casting a pointer to a pointer of the same type is pointless,
so remove these unnecessary casts.
Done via coccinelle script:
$ cat typecast_2.cocci
type T;
T *foo;
- (T *)foo
+ foo
Signed-off-by: Joe Perches
Acked-by: Vince Bridgers
drivers/net/ethernet/altera/altera_tse_main.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ethernet/altera/altera_tse_main.c b/drivers/net/ethernet/altera/altera_tse_main.c
index 6006ef2..c70a29e 100644
--- a/drivers/net/ethernet/altera/altera_tse_main.c
+++ b/drivers/net/ethernet/altera/altera_tse_main.c
@@ -933,7 +933,7 @@ static int tse_change_mtu(struct net_device *dev, int new_mtu)
static void altera_tse_set_mcfilter(struct net_device *dev)
struct altera_tse_private *priv = netdev_priv(dev);
- struct altera_tse_mac *mac = (struct altera_tse_mac *)priv->mac_dev;
+ struct altera_tse_mac *mac = priv->mac_dev;
int i;
struct netdev_hw_addr *ha;
@@ -963,7 +963,7 @@ static void altera_tse_set_mcfilter(struct net_device *dev)
static void altera_tse_set_mcfilterall(struct net_device *dev)
int i;
/* set the hash filter */ |
int i;
int i;
