perf/x86/uncore: Fix coccinelle warnings
Author: Fengguang Wu <fengguang.wu@intel.com>
  arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c:961:2-3: Unneeded semicolon
  arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c:1100:2-3: Unneeded semicolon
  arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c:1138:2-3: Unneeded semicolon
Remove unneeded semicolon.
Generated by: scripts/coccinelle/misc/semicolon.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Peter Zijlstra
Cc: Yan, Zheng
Cc: Arnaldo Carvalho de Melo
Link: http://lkml.kernel.org/n/tip-ovfvr4nbqjo7nzc16y2lpjy9@git.kernel.org
Signed-off-by: Ingo Molnar
 arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c b/arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c
index 93b11a8..2749965 100644
--- a/arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c
+++ b/arch/x86/kernel/cpu/perf_event_intel_uncore_nhmex.c
@@ -958,7 +958,7 @@ static void nhmex_rbox_alter_er(struct intel_uncore_box *box, struct perf_event
 		/* shift the 0~7 bits to the 8~15 bits */
 		reg1->config <<= 8;
 		break;
@@ -1097,7 +1097,7 @@ static int nhmex_rbox_hw_config(struct intel_uncore_box *box, struct perf_event
 		hwc->config |= event->attr.config & (~0ULL << 32);
 		reg2->config = event->attr.config2;
 		break;
 	return 0;
@@ -1135,7 +1135,7 @@ static void nhmex_rbox_msr_enable_event(struct intel_uncore_box *box, struct per
 		wrmsrl(NHMEX_R_MSR_PORTN_XBR_SET2_MATCH(port), reg1->config);
 		wrmsrl(NHMEX_R_MSR_PORTN_XBR_SET2_MASK(port), reg2->config);
 		break;
 	wrmsrl(hwc->config_base, NHMEX_PMON_CTL_EN_BIT0 |
 		(hwc->config & NHMEX_R_PMON_CTL_EV_SEL_MASK));
BtrLinux
