staging: lustre: obdclass: expand double GOTO macros
(http://coccinelle.lip6.fr/)
identifier lbl;
if (...)
  GOTO(lbl,...);
+else
GOTO(lbl,...);
identifier lbl;
expression e,e1,e2;
if (e)
-  GOTO(lbl,e1);
-else GOTO(lbl,e2);
+  e1;
+else e2;
+goto lbl;
identifier lbl1,lbl2;
expression e,e1,e2;
+ e1=e2;
if (e)
-  GOTO(lbl1,e1=e2);
-GOTO(lbl2,e1=e2);
+  goto lbl1;
+goto lbl2;
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/obdclass/dt_object.c | 6 ++++--
 drivers/staging/lustre/lustre/obdclass/llog.c      | 5 +++--
 2 files changed, 7 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/dt_object.c b/drivers/staging/lustre/lustre/obdclass/dt_object.c
index 130b8dd..4060173 100644
--- a/drivers/staging/lustre/lustre/obdclass/dt_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/dt_object.c
@@ -689,8 +689,10 @@ static int dt_index_page_build(const struct lu_env *env, union lu_page *lp,
 		if (nob < size) {
 			if (lip->lip_nr == 0)
-				GOTO(out, rc = -EINVAL);
-			GOTO(out, rc = 0);
+				rc = -EINVAL;
+			else
+				rc = 0;
+			goto out;
 		if ((ii->ii_flags & II_FL_NOHASH) == 0) {
diff --git a/drivers/staging/lustre/lustre/obdclass/llog.c b/drivers/staging/lustre/lustre/obdclass/llog.c
index ebdc42f..1cf604d 100644
--- a/drivers/staging/lustre/lustre/obdclass/llog.c
+++ b/drivers/staging/lustre/lustre/obdclass/llog.c
@@ -336,9 +336,10 @@ repeat:
 			if (rec->lrh_index == 0) {
 				/* probably another rec just got added? */
+				rc = 0;
 				if (index <= loghandle->lgh_last_idx)
-					GOTO(repeat, rc = 0);
-				GOTO(out, rc = 0); /* no more records */
+					goto repeat;
+				goto out; /* no more records */
 			if (rec->lrh_len == 0 ||
 			    rec->lrh_len > LLOG_CHUNK_SIZE) {
BtrLinux
Privacy Overview
