staging: dgnc: dgnc_neo.c: Replace non-standard spinlock’s macros
Author: Roberta Dobrescu <roberta.dobrescu@gmail.com>
This patch replaces non-standard spinlock's macros.
It is done using coccinelle and the following semantic patch:
expression x;
- DGNC_SPINLOCK_INIT(x)
+ spin_lock_init(&x)
expression x, y;
- DGNC_LOCK(x, y)
+ spin_lock_irqsave(&x, y)
expression x, y;
- DGNC_UNLOCK(x, y)
+ spin_unlock_irqrestore(&x, y)
@used_by_lock exists@
typedef ulong;
symbol lock_flags;
position p1, p2;
 ulong lock_flags@p1;
 unsigned long lock_flags@p2;
 spin_lock_irqsave(..., lock_flags)
 spin_unlock_irqrestore(..., lock_flags)
position used_by_lock.p1, used_by_lock.p2;
- ulong lock_flags@p1;
+ unsigned long flags;
- unsigned long lock_flags@p2;
- lock_flags
+ flags
Additionally replace 'lock_flags2' with 'flags2'.
This was done by hand since it had only 3 occurences and all in this file.
Signed-off-by: Roberta Dobrescu
 drivers/staging/dgnc/dgnc_neo.c | 120 ++++++++++++++++++++++------------------
 1 file changed, 66 insertions(+), 54 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_neo.c b/drivers/staging/dgnc/dgnc_neo.c
index d6f4a80..9c8f06b 100644
--- a/drivers/staging/dgnc/dgnc_neo.c
+++ b/drivers/staging/dgnc/dgnc_neo.c
@@ -368,13 +368,13 @@ static inline void neo_set_new_start_stop_chars(struct channel_t *ch)
 static inline void neo_clear_break(struct channel_t *ch, int force)
-	ulong lock_flags;
-	DGNC_LOCK(ch->ch_lock, lock_flags);
+	spin_lock_irqsave(&ch->ch_lock, flags);
 	/* Bail if we aren't currently sending a break. */
 	if (!ch->ch_stop_sending_break) {
-		DGNC_UNLOCK(ch->ch_lock, lock_flags);
+		spin_unlock_irqrestore(&ch->ch_lock, flags);
 		return;
@@ -390,7 +390,7 @@ static inline void neo_clear_break(struct channel_t *ch, int force)
 			ch->ch_stop_sending_break = 0;
@@ -402,7 +402,7 @@ static inline void neo_parse_isr(struct dgnc_board *brd, uint port)
 	struct channel_t *ch;
 	uchar isr;
 	uchar cause;
-	ulong lock_flags;
 	if (!brd || brd->magic != DGNC_BOARD_MAGIC)
 		return;
@@ -435,18 +435,18 @@ static inline void neo_parse_isr(struct dgnc_board *brd, uint port)
 			neo_copy_data_from_uart_to_queue(ch);
 			/* Call our tty layer to enforce queue flow control if needed. */
 			dgnc_check_queue_flow_control(ch);
 		if (isr & UART_IIR_THRI) {
 			brd->intr_tx++;
 			ch->ch_intr_tx++;
 			/* Transfer data (if any) from Write Queue -> UART. */
 			ch->ch_flags |= (CH_TX_FIFO_EMPTY | CH_TX_FIFO_LWM);
 			neo_copy_data_from_queue_to_uart(ch);
@@ -461,15 +461,19 @@ static inline void neo_parse_isr(struct dgnc_board *brd, uint port)
 			if (cause == UART_17158_XON_DETECT) {
 				/* Is output stopped right now, if so, resume it */
 				if (brd->channels[port]->ch_flags & CH_STOP) {
+							  flags);
 					ch->ch_flags &= ~(CH_STOP);
+							       flags);
 			} else if (cause == UART_17158_XOFF_DETECT) {
 				if (!(brd->channels[port]->ch_flags & CH_STOP)) {
+							  flags);
 					ch->ch_flags |= CH_STOP;
+							       flags);
@@ -485,23 +489,31 @@ static inline void neo_parse_isr(struct dgnc_board *brd, uint port)
 			/* Which pin is doing auto flow? RTS or DTR? */
 			if ((cause & 0x4) == 0) {
 				if (cause & UART_MCR_RTS) {
+							  flags);
 					ch->ch_mostat |= UART_MCR_RTS;
+							       flags);
 				} else {
+							  flags);
 					ch->ch_mostat &= ~(UART_MCR_RTS);
+							       flags);
 			} else {
 				if (cause & UART_MCR_DTR) {
+							  flags);
 					ch->ch_mostat |= UART_MCR_DTR;
+							       flags);
 				} else {
+							  flags);
 					ch->ch_mostat &= ~(UART_MCR_DTR);
+							       flags);
@@ -516,7 +528,7 @@ static inline void neo_parse_lsr(struct dgnc_board *brd, uint port)
 	int linestatus;
-	ulong lock_flags;
 	if (!brd)
 		return;
@@ -540,9 +552,9 @@ static inline void neo_parse_lsr(struct dgnc_board *brd, uint port)
 		ch->ch_intr_rx++;
 		/* Read data from uart -> queue */
@@ -572,18 +584,18 @@ static inline void neo_parse_lsr(struct dgnc_board *brd, uint port)
 	if (linestatus & UART_LSR_THRE) {
 		brd->intr_tx++;
 		ch->ch_intr_tx++;
 	} else if (linestatus & UART_17158_TX_AND_FIFO_CLR) {
 		brd->intr_tx++;
 		ch->ch_intr_tx++;
@@ -852,7 +864,7 @@ static void neo_tasklet(unsigned long data)
 	struct dgnc_board *bd = (struct dgnc_board *) data;
-	ulong  lock_flags;
 	int i;
 	int state = 0;
 	int ports = 0;
@@ -863,16 +875,16 @@ static void neo_tasklet(unsigned long data)
 	/* Cache a couple board values */
-	DGNC_LOCK(bd->bd_lock, lock_flags);
+	spin_lock_irqsave(&bd->bd_lock, flags);
 	state = bd->state;
 	ports = bd->nasync;
-	DGNC_UNLOCK(bd->bd_lock, lock_flags);
+	spin_unlock_irqrestore(&bd->bd_lock, flags);
 	 * Do NOT allow the interrupt routine to read the intr registers
 	 * Until we release this lock.
-	DGNC_LOCK(bd->bd_intr_lock, lock_flags);
+	spin_lock_irqsave(&bd->bd_intr_lock, flags);
 	 * If board is ready, parse deeper to see if there is anything to do.
@@ -921,7 +933,7 @@ static void neo_tasklet(unsigned long data)
 	/* Allow interrupt routine to access the interrupt register again */
-	DGNC_UNLOCK(bd->bd_intr_lock, lock_flags);
+	spin_unlock_irqrestore(&bd->bd_intr_lock, flags);
@@ -940,8 +952,8 @@ static irqreturn_t neo_intr(int irq, void *voidbrd)
 	int current_port;
 	u32 tmp;
 	u32 uart_poll;
-	unsigned long lock_flags;
-	unsigned long lock_flags2;
+	unsigned long flags2;
 	if (!brd) {
 		APR(("Received interrupt (%d) with null board associated\n", irq));
@@ -959,7 +971,7 @@ static irqreturn_t neo_intr(int irq, void *voidbrd)
 	brd->intr_count++;
 	/* Lock out the slow poller from running on this board. */
-	DGNC_LOCK(brd->bd_intr_lock, lock_flags);
+	spin_lock_irqsave(&brd->bd_intr_lock, flags);
 	 * Read in "extended" IRQ information from the 32bit Neo register.
@@ -973,7 +985,7 @@ static irqreturn_t neo_intr(int irq, void *voidbrd)
 	 * This can happen if the IRQ is shared among a couple Neo/Classic boards.
 	if (!uart_poll) {
-		DGNC_UNLOCK(brd->bd_intr_lock, lock_flags);
+		spin_unlock_irqrestore(&brd->bd_intr_lock, flags);
 		return IRQ_NONE;
@@ -1021,9 +1033,9 @@ static irqreturn_t neo_intr(int irq, void *voidbrd)
-			DGNC_LOCK(ch->ch_lock, lock_flags2);
+			spin_lock_irqsave(&ch->ch_lock, flags2);
-			DGNC_UNLOCK(ch->ch_lock, lock_flags2);
+			spin_unlock_irqrestore(&ch->ch_lock, flags2);
 			continue;
@@ -1073,7 +1085,7 @@ static irqreturn_t neo_intr(int irq, void *voidbrd)
 	tasklet_schedule(&brd->helper_tasklet);
 	return IRQ_HANDLED;
@@ -1118,12 +1130,12 @@ static void neo_copy_data_from_uart_to_queue(struct channel_t *ch)
 	int total = 0;
 	ushort head;
 	ushort tail;
-	ulong lock_flags;
 	if (!ch || ch->magic != DGNC_CHANNEL_MAGIC)
 		return;
 	/* cache head and tail of queue */
 	head = ch->ch_r_head & RQUEUEMASK;
@@ -1316,7 +1328,7 @@ static void neo_copy_data_from_uart_to_queue(struct channel_t *ch)
 	ch->ch_r_head = head & RQUEUEMASK;
 	ch->ch_e_head = head & EQUEUEMASK;
@@ -1326,7 +1338,7 @@ static void neo_copy_data_from_uart_to_queue(struct channel_t *ch)
 static int neo_drain(struct tty_struct *tty, uint seconds)
-	ulong lock_flags;
 	struct un_t *un;
 	int rc = 0;
@@ -1342,9 +1354,9 @@ static int neo_drain(struct tty_struct *tty, uint seconds)
 		return -ENXIO;
 	un->un_flags |= UN_EMPTY;
 	 * Go to sleep waiting for the tty layer to wake me back up when
@@ -1425,22 +1437,22 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
 	int s;
 	int qlen;
 	uint len_written = 0;
-	ulong lock_flags;
 		return;
 	/* No data to write to the UART */
 	if (ch->ch_w_tail == ch->ch_w_head) {
 		return;
 	/* If port is "stopped", don't send any data to the UART */
 	if ((ch->ch_flags & CH_FORCED_STOP) || (ch->ch_flags & CH_BREAK_SENDING)) {
 		return;
@@ -1483,7 +1495,7 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
 			ch->ch_w_tail &= WQUEUEMASK;
 			ch->ch_txcount++;
 		return;
@@ -1492,7 +1504,7 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
 	if ((ch->ch_bd->dvid & 0xf0) < UART_XR17E158_DVID) {
 		if (!(ch->ch_flags & (CH_TX_FIFO_EMPTY | CH_TX_FIFO_LWM))) {
 			return;
@@ -1501,7 +1513,7 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
 		n = readb(&ch->ch_neo_uart->tfifo);
 		if ((unsigned int) n > ch->ch_t_tlevel) {
 			return;
@@ -1568,7 +1580,7 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
 		ch->ch_flags &= ~(CH_TX_FIFO_EMPTY | CH_TX_FIFO_LWM);
BtrLinux
Privacy Overview
