xhci: Use setup_timer
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.data = d;
-t.function = f;
Signed-off-by: Julia Lawall
Signed-off-by: Mathias Nyman
 drivers/usb/host/xhci.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c
index 5ec74e2..1e3f39c 100644
--- a/drivers/usb/host/xhci.c
+++ b/drivers/usb/host/xhci.c
@@ -472,10 +472,8 @@ static void compliance_mode_recovery(unsigned long arg)
 static void compliance_mode_recovery_timer_init(struct xhci_hcd *xhci)
 	xhci->port_status_u0 = 0;
-	init_timer(&xhci->comp_mode_recovery_timer);
-	xhci->comp_mode_recovery_timer.data = (unsigned long) xhci;
-	xhci->comp_mode_recovery_timer.function = compliance_mode_recovery;
+	setup_timer(&xhci->comp_mode_recovery_timer,
+		    compliance_mode_recovery, (unsigned long)xhci);
 	xhci->comp_mode_recovery_timer.expires = jiffies +
 			msecs_to_jiffies(COMP_MODE_RCVRY_MSECS);
BtrLinux
Privacy Overview
