[media] saa7164: Replace if and BUG with BUG_ON
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace if condition and BUG() with a BUG_ON having the conditional
expression of the if statement as argument.
The Coccinelle semantic patch used to make this change is as follows:
@@ expression E,f; @@
  if (<+... f(...) ...+>) { BUG(); }
- if (E) { BUG(); }
+ BUG_ON(E);
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/pci/saa7164/saa7164-encoder.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/media/pci/saa7164/saa7164-encoder.c b/drivers/media/pci/saa7164/saa7164-encoder.c
index 1b184c3..32a353d 100644
--- a/drivers/media/pci/saa7164/saa7164-encoder.c
+++ b/drivers/media/pci/saa7164/saa7164-encoder.c
@@ -1022,8 +1022,7 @@ int saa7164_encoder_register(struct saa7164_port *port)
 	dprintk(DBGLVL_ENC, "%s()\n", __func__);
-	if (port->type != SAA7164_MPEG_ENCODER)
-		BUG();
+	BUG_ON(port->type != SAA7164_MPEG_ENCODER);
 	/* Sanity check that the PCI configuration space is active */
 	if (port->hwcfg.BARLocation == 0) {
@@ -1151,8 +1150,7 @@ void saa7164_encoder_unregister(struct saa7164_port *port)
 	dprintk(DBGLVL_ENC, "%s(port=%d)\n", __func__, port->nr);
-		BUG();
 	if (port->v4l_device) {
 		if (port->v4l_device->minor != -1)
BtrLinux
Privacy Overview
