drm/etnaviv: Delete unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions drm_gem_object_unreference_unlocked() and vunmap() perform
also input parameter validation.
Thus the tests around their calls are not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
[seanpaul tweaked subject]
Signed-off-by: Sean Paul
Link: http://patchwork.freedesktop.org/patch/msgid/9638cd74-ffc5-d9ee-a40c-9b60e860ad8b@users.sourceforge.net
 drivers/gpu/drm/etnaviv/etnaviv_gem.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/gpu/drm/etnaviv/etnaviv_gem.c b/drivers/gpu/drm/etnaviv/etnaviv_gem.c
index df9bcba..356056a 100644
--- a/drivers/gpu/drm/etnaviv/etnaviv_gem.c
+++ b/drivers/gpu/drm/etnaviv/etnaviv_gem.c
@@ -535,8 +535,7 @@ void etnaviv_gem_describe_objects(struct etnaviv_drm_private *priv,
 static void etnaviv_gem_shmem_release(struct etnaviv_gem_object *etnaviv_obj)
-	if (etnaviv_obj->vaddr)
-		vunmap(etnaviv_obj->vaddr);
+	vunmap(etnaviv_obj->vaddr);
 	put_pages(etnaviv_obj);
@@ -670,9 +669,7 @@ static struct drm_gem_object *__etnaviv_gem_new(struct drm_device *dev,
 	return obj;
 fail:
-	if (obj)
-		drm_gem_object_unreference_unlocked(obj);
+	drm_gem_object_unreference_unlocked(obj);
 	return ERR_PTR(ret);
