drivers/amdgpu: Remove redundant NULL check before kfree()
Author: Edward O'Callaghan <funfunctor@folklore1984.net>
Found-by: Coccinelle
Signed-off-by: Edward O'Callaghan
Reviewed-by: Tom St Denis
Reviewed-by: Christian König
Signed-off-by: Alex Deucher
 drivers/gpu/drm/amd/amdgpu/amdgpu_cgs.c              | 3 +--
 drivers/gpu/drm/amd/powerplay/hwmgr/functiontables.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/gpu/drm/amd/amdgpu/amdgpu_cgs.c b/drivers/gpu/drm/amd/amdgpu/amdgpu_cgs.c
index ee95e95..4cd857f 100644
--- a/drivers/gpu/drm/amd/amdgpu/amdgpu_cgs.c
+++ b/drivers/gpu/drm/amd/amdgpu/amdgpu_cgs.c
@@ -1065,8 +1065,7 @@ static int amdgpu_cgs_acpi_eval_object(struct cgs_device *cgs_device,
 error:
-	if (obj != NULL)
-		kfree(obj);
+	kfree(obj);
 	kfree((void *)input.pointer);
 	return result;
diff --git a/drivers/gpu/drm/amd/powerplay/hwmgr/functiontables.c b/drivers/gpu/drm/amd/powerplay/hwmgr/functiontables.c
index 7a705ce..bbdedec 100644
--- a/drivers/gpu/drm/amd/powerplay/hwmgr/functiontables.c
+++ b/drivers/gpu/drm/amd/powerplay/hwmgr/functiontables.c
@@ -77,8 +77,7 @@ int phm_dispatch_table(struct pp_hwmgr *hwmgr,
 	result = phm_run_table(hwmgr, rt_table, input, output, temp_storage);
-	if (NULL != temp_storage)
-		kfree(temp_storage);
+	kfree(temp_storage);
 	return result;
BtrLinux
Privacy Overview
