irqchip/imgpdc: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_handler_data(E1, E2) != 0)
-   BUG();
-irq_set_handler_data(E1, E2);
-irq_set_chained_handler(E1, E3);
+irq_set_chained_handler_and_data(E1, E3, E2);
-   BUG();
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Thomas Gleixner
Cc: Jason Cooper
 drivers/irqchip/irq-imgpdc.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/irqchip/irq-imgpdc.c b/drivers/irqchip/irq-imgpdc.c
index 8071c2e..03d91cb 100644
--- a/drivers/irqchip/irq-imgpdc.c
+++ b/drivers/irqchip/irq-imgpdc.c
@@ -451,13 +451,13 @@ static int pdc_intc_probe(struct platform_device *pdev)
 	/* Setup chained handlers for the peripheral IRQs */
 	for (i = 0; i < priv->nr_perips; ++i) {
 		irq = priv->perip_irqs[i];
-		irq_set_handler_data(irq, priv);
-		irq_set_chained_handler(irq, pdc_intc_perip_isr);
+		irq_set_chained_handler_and_data(irq, pdc_intc_perip_isr,
+						 priv);
 	/* Setup chained handler for the syswake IRQ */
-	irq_set_handler_data(priv->syswake_irq, priv);
-	irq_set_chained_handler(priv->syswake_irq, pdc_intc_syswake_isr);
+	irq_set_chained_handler_and_data(priv->syswake_irq,
+					 pdc_intc_syswake_isr, priv);
 	dev_info(&pdev->dev,
 		 "PDC IRQ controller initialised (%u perip IRQs, %u syswake IRQs)\n",
BtrLinux
Privacy Overview
