irqchip/versatile-fpga: Prepare fpga_irq_handle for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
 drivers/irqchip/irq-versatile-fpga.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/irqchip/irq-versatile-fpga.c b/drivers/irqchip/irq-versatile-fpga.c
index 70088bb..16123f6 100644
--- a/drivers/irqchip/irq-versatile-fpga.c
+++ b/drivers/irqchip/irq-versatile-fpga.c
@@ -65,9 +65,10 @@ static void fpga_irq_unmask(struct irq_data *d)
 	writel(mask, f->base + IRQ_ENABLE_SET);
-static void fpga_irq_handle(unsigned int irq, struct irq_desc *desc)
+static void fpga_irq_handle(unsigned int __irq, struct irq_desc *desc)
 	struct fpga_irq_data *f = irq_desc_get_handler_data(desc);
+	unsigned int irq = irq_desc_get_irq(desc);
 	u32 status = readl(f->base + IRQ_STATUS);
 	if (status == 0) {
BtrLinux
Privacy Overview
