spmi/pmic_arb: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Greg Kroah-Hartman
Cc: Jiang Liu
Cc: Julia Lawall
Link: http://lkml.kernel.org/r/20150713151750.831790045@linutronix.de
Signed-off-by: Ingo Molnar
 drivers/spmi/spmi-pmic-arb.c | 9 +++------
 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/spmi/spmi-pmic-arb.c b/drivers/spmi/spmi-pmic-arb.c
index d7119db..db2aac1 100644
--- a/drivers/spmi/spmi-pmic-arb.c
+++ b/drivers/spmi/spmi-pmic-arb.c
@@ -928,8 +928,7 @@ static int spmi_pmic_arb_probe(struct platform_device *pdev)
 		goto err_put_ctrl;
-	irq_set_handler_data(pa->irq, pa);
-	irq_set_chained_handler(pa->irq, pmic_arb_chained_irq);
+	irq_set_chained_handler_and_data(pa->irq, pmic_arb_chained_irq, pa);
 	err = spmi_controller_add(ctrl);
 	if (err)
@@ -938,8 +937,7 @@ static int spmi_pmic_arb_probe(struct platform_device *pdev)
 	return 0;
 err_domain_remove:
-	irq_set_chained_handler(pa->irq, NULL);
-	irq_set_handler_data(pa->irq, NULL);
+	irq_set_chained_handler_and_data(pa->irq, NULL, NULL);
 	irq_domain_remove(pa->domain);
 err_put_ctrl:
 	spmi_controller_put(ctrl);
@@ -951,8 +949,7 @@ static int spmi_pmic_arb_remove(struct platform_device *pdev)
 	struct spmi_controller *ctrl = platform_get_drvdata(pdev);
 	struct spmi_pmic_arb_dev *pa = spmi_controller_get_drvdata(ctrl);
 	spmi_controller_remove(ctrl);
 	return 0;
