ASoC: tpa6130a2: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Acked-by: Peter Ujfalusi
Signed-off-by: Mark Brown
 sound/soc/codecs/tpa6130a2.c | 14 ++++++--------
 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/sound/soc/codecs/tpa6130a2.c b/sound/soc/codecs/tpa6130a2.c
index 6fac9e0..1e1d4ab 100644
--- a/sound/soc/codecs/tpa6130a2.c
+++ b/sound/soc/codecs/tpa6130a2.c
@@ -259,8 +259,7 @@ static int tpa6130a2_put_volsw(struct snd_kcontrol *kcontrol,
  * TPA6130 volume. From -59.5 to 4 dB with increasing step size when going
  * down in gain.
-static const unsigned int tpa6130_tlv[] = {
-	TLV_DB_RANGE_HEAD(10),
+static const DECLARE_TLV_DB_RANGE(tpa6130_tlv,
 	0, 1, TLV_DB_SCALE_ITEM(-5950, 600, 0),
 	2, 3, TLV_DB_SCALE_ITEM(-5000, 250, 0),
 	4, 5, TLV_DB_SCALE_ITEM(-4550, 160, 0),
@@ -270,8 +269,8 @@ static const unsigned int tpa6130_tlv[] = {
 	12, 13, TLV_DB_SCALE_ITEM(-3040, 180, 0),
 	14, 20, TLV_DB_SCALE_ITEM(-2710, 110, 0),
 	21, 37, TLV_DB_SCALE_ITEM(-1960, 74, 0),
-	38, 63, TLV_DB_SCALE_ITEM(-720, 45, 0),
+	38, 63, TLV_DB_SCALE_ITEM(-720, 45, 0)
 static const struct snd_kcontrol_new tpa6130a2_controls[] = {
 	SOC_SINGLE_EXT_TLV("TPA6130A2 Headphone Playback Volume",
@@ -280,12 +279,11 @@ static const struct snd_kcontrol_new tpa6130a2_controls[] = {
 		       tpa6130_tlv),
-static const unsigned int tpa6140_tlv[] = {
-	TLV_DB_RANGE_HEAD(3),
+static const DECLARE_TLV_DB_RANGE(tpa6140_tlv,
 	0, 8, TLV_DB_SCALE_ITEM(-5900, 400, 0),
 	9, 16, TLV_DB_SCALE_ITEM(-2500, 200, 0),
-	17, 31, TLV_DB_SCALE_ITEM(-1000, 100, 0),
+	17, 31, TLV_DB_SCALE_ITEM(-1000, 100, 0)
 static const struct snd_kcontrol_new tpa6140a2_controls[] = {
 	SOC_SINGLE_EXT_TLV("TPA6140A2 Headphone Playback Volume",
BtrLinux
