staging/lustre: use kmemdup rather than duplicating its implementation
Author: Andrzej Hajda <a.hajda@samsung.com>
The patch was generated using fixed coccinelle semantic patch
scripts/coccinelle/api/memdup.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2014320
Signed-off-by: Andrzej Hajda
 drivers/staging/lustre/lustre/obdclass/acl.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/acl.c b/drivers/staging/lustre/lustre/obdclass/acl.c
index bc3fc47..933456c 100644
--- a/drivers/staging/lustre/lustre/obdclass/acl.c
+++ b/drivers/staging/lustre/lustre/obdclass/acl.c
@@ -104,11 +104,10 @@ static int lustre_posix_acl_xattr_reduce_space(posix_acl_xattr_header **header,
 	if (unlikely(old_count <= new_count))
 		return old_size;
-	new = kzalloc(new_size, GFP_NOFS);
+	new = kmemdup(*header, new_size, GFP_NOFS);
 	if (unlikely(new == NULL))
 		return -ENOMEM;
-	memcpy(new, *header, new_size);
 	kfree(*header);
 	*header = new;
 	return new_size;
@@ -125,11 +124,10 @@ static int lustre_ext_acl_xattr_reduce_space(ext_acl_xattr_header **header,
 	if (unlikely(old_count <= ext_count))
 		return 0;
-	new = kzalloc(ext_size, GFP_NOFS);
+	new = kmemdup(*header, ext_size, GFP_NOFS);
 		return -ENOMEM;
-	memcpy(new, *header, ext_size);
 	kfree(*header);
 	*header = new;
 	return 0;
BtrLinux
Privacy Overview
