wm831x_power: Use IRQF_ONESHOT to request threaded IRQs
Author: Valentin Rothberg <valentinrothberg@gmail.com>
Since commit 1c6c69525b40 ("genirq: Reject bogus threaded irq requests")
threaded IRQs without a primary handler need to be requested with
IRQF_ONESHOT, otherwise the request will fail.
scripts/coccinelle/misc/irqf_oneshot.cocci detected this issue.
Fixes: b5874f33bbaf ("wm831x_power: Use genirq")
Signed-off-by: Valentin Rothberg
Signed-off-by: Sebastian Reichel
 drivers/power/wm831x_power.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/power/wm831x_power.c b/drivers/power/wm831x_power.c
index c826c83..7082301 100644
--- a/drivers/power/wm831x_power.c
+++ b/drivers/power/wm831x_power.c
@@ -573,7 +573,7 @@ static int wm831x_power_probe(struct platform_device *pdev)
 	irq = wm831x_irq(wm831x, platform_get_irq_byname(pdev, "SYSLO"));
 	ret = request_threaded_irq(irq, NULL, wm831x_syslo_irq,
-				   IRQF_TRIGGER_RISING, "System power low",
+				   IRQF_TRIGGER_RISING | IRQF_ONESHOT, "System power low",
 				   power);
 	if (ret != 0) {
 		dev_err(&pdev->dev, "Failed to request SYSLO IRQ %d: %d\n",
@@ -583,7 +583,7 @@ static int wm831x_power_probe(struct platform_device *pdev)
 	irq = wm831x_irq(wm831x, platform_get_irq_byname(pdev, "PWR SRC"));
 	ret = request_threaded_irq(irq, NULL, wm831x_pwr_src_irq,
-				   IRQF_TRIGGER_RISING, "Power source",
+				   IRQF_TRIGGER_RISING | IRQF_ONESHOT, "Power source",
 				   power);
 	if (ret != 0) {
 		dev_err(&pdev->dev, "Failed to request PWR SRC IRQ %d: %d\n",
@@ -596,7 +596,7 @@ static int wm831x_power_probe(struct platform_device *pdev)
 							 wm831x_bat_irqs[i]));
 		ret = request_threaded_irq(irq, NULL, wm831x_bat_irq,
 					   wm831x_bat_irqs[i],
 					   power);
 		if (ret != 0) {
BtrLinux
Privacy Overview
