soc: qcom: smd: delete unneeded of_node_put
Device node iterators perform an of_node_put on each iteration, so putting
an of_node_put before a continue results in a double put.
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
iterator i;
 i(..., child, ...) {
   ... when != of_node_get(child)
*  of_node_put(child);
*  continue;
Signed-off-by: Julia Lawall
Signed-off-by: Andy Gross
 drivers/soc/qcom/smd.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/soc/qcom/smd.c b/drivers/soc/qcom/smd.c
index ef5fed6..86b598c 100644
--- a/drivers/soc/qcom/smd.c
+++ b/drivers/soc/qcom/smd.c
@@ -921,10 +921,8 @@ static struct device_node *qcom_smd_match_channel(struct device_node *edge_node,
 	for_each_available_child_of_node(edge_node, child) {
 		key = "qcom,smd-channels";
 		ret = of_property_read_string(child, key, &name);
-		if (ret) {
-			of_node_put(child);
+		if (ret)
 			continue;
 		if (strcmp(name, channel) == 0)
 			return child;
BtrLinux
