of/platform: add missing of_node_put
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
local idexpression n;
expression root,e;
 for_each_child_of_node(root,n) {
   of_node_put(n);
   e = n
+  of_node_put(n);
?  break;
... when != n
Signed-off-by: Julia Lawall
Signed-off-by: Rob Herring
 drivers/of/platform.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/of/platform.c b/drivers/of/platform.c
index 1001efa..af98343 100644
--- a/drivers/of/platform.c
+++ b/drivers/of/platform.c
@@ -405,8 +405,10 @@ int of_platform_bus_probe(struct device_node *root,
 		if (!of_match_node(matches, child))
 			continue;
 		rc = of_platform_bus_create(child, matches, NULL, parent, false);
-		if (rc)
+		if (rc) {
+			of_node_put(child);
 			break;
 	of_node_put(root);
@@ -447,8 +449,10 @@ int of_platform_populate(struct device_node *root,
 	for_each_child_of_node(root, child) {
 		rc = of_platform_bus_create(child, matches, lookup, parent, true);
-		if (rc)
+		if (rc) {
 			break;
 	of_node_set_flag(root, OF_POPULATED_BUS);
BtrLinux
