MIPS: Remove invalid check
Author: Andrzej Hajda <a.hajda@samsung.com>
Unsigned values cannot be lesser than zero.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[ralf@linux-mips.org: Chris Dearman's original commit
9318c51acd9689505850152cc98277a6d6f2d752 ([MIPS] MIPS32/MIPS64 secondary
cache management) introduced these less than zero checks in 2.6.18.]
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Cc: linux-kernel@vger.kernel.org
Cc: Bartlomiej Zolnierkiewicz
Cc: Marek Szyprowski
Cc: Markos Chandras
Cc: Chris Dearman
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/11165/
Signed-off-by: Ralf Baechle
 arch/mips/mm/sc-mips.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/mm/sc-mips.c b/arch/mips/mm/sc-mips.c
index 53ea839..1755187 100644
--- a/arch/mips/mm/sc-mips.c
+++ b/arch/mips/mm/sc-mips.c
@@ -162,13 +162,13 @@ static inline int __init mips_sc_probe(void)
 		return 0;
 	tmp = (config2 >> 8) & 0x0f;
-	if (0 <= tmp && tmp <= 7)
+	if (tmp <= 7)
 		c->scache.sets = 64 << tmp;
 	else
 		return 0;
 	tmp = (config2 >> 0) & 0x0f;
+	if (tmp <= 7)
 		c->scache.ways = tmp + 1;
 	else
 		return 0;
BtrLinux
Privacy Overview
