arm: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
The of_node_put is duplicated in front of each error return, because the
function contains a later error return that is beyond the end of the
for_each_child_of_node and thus doesn't need of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
iterator name for_each_child_of_node;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
expression root,e;
       when != e = child
?  break;
... when != child
Additionally, concatenated a string in an affected line to avoid introducing
a checkpatch warning.
Signed-off-by: Julia Lawall
Signed-off-by: Russell King
 arch/arm/kernel/devtree.c | 12 +++++++++---
 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/arm/kernel/devtree.c b/arch/arm/kernel/devtree.c
index 11c54de..65addcb 100644
--- a/arch/arm/kernel/devtree.c
+++ b/arch/arm/kernel/devtree.c
@@ -101,6 +101,7 @@ void __init arm_dt_init_cpu_maps(void)
 		if (of_property_read_u32(cpu, "reg", &hwid)) {
 			pr_debug(" * %s missing reg property\n",
 				     cpu->full_name);
+			of_node_put(cpu);
 			return;
@@ -108,8 +109,10 @@ void __init arm_dt_init_cpu_maps(void)
 		 * 8 MSBs must be set to 0 in the DT since the reg property
 		 * defines the MPIDR[23:0].
-		if (hwid & ~MPIDR_HWID_BITMASK)
+		if (hwid & ~MPIDR_HWID_BITMASK) {
+			of_node_put(cpu);
 			return;
 		 * Duplicate MPIDRs are a recipe for disaster.
@@ -119,9 +122,11 @@ void __init arm_dt_init_cpu_maps(void)
 		 * to avoid matching valid MPIDR[23:0] values.
 		for (j = 0; j < cpuidx; j++)
-			if (WARN(tmp_map[j] == hwid, "Duplicate /cpu reg "
-						     "properties in the DT\n"))
+			if (WARN(tmp_map[j] == hwid,
+				 "Duplicate /cpu reg properties in the DT\n")) {
+				of_node_put(cpu);
 				return;
 		 * Build a stashed array of MPIDR values. Numbering scheme
@@ -143,6 +148,7 @@ void __init arm_dt_init_cpu_maps(void)
 					       "max cores %u, capping them\n",
 					       cpuidx, nr_cpu_ids)) {
 			cpuidx = nr_cpu_ids;
+			of_node_put(cpu);
 			break;
BtrLinux
