backlight: pm8941-wled: Fix ptr_ret.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/video/backlight/pm8941-wled.c:404:1-3: WARNING: PTR_ERR_OR_ZERO can be used
 Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: scripts/coccinelle/api/ptr_ret.cocci
Acked-by: Bjorn Andersson
Signed-off-by: Fengguang Wu
Signed-off-by: Lee Jones
 drivers/video/backlight/pm8941-wled.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/video/backlight/pm8941-wled.c b/drivers/video/backlight/pm8941-wled.c
index c704c32..78bba87 100644
--- a/drivers/video/backlight/pm8941-wled.c
+++ b/drivers/video/backlight/pm8941-wled.c
@@ -401,10 +401,7 @@ static int pm8941_wled_probe(struct platform_device *pdev)
 	bl = devm_backlight_device_register(&pdev->dev, wled->name,
 					    &pdev->dev, wled,
 					    &pm8941_wled_ops, &props);
-	if (IS_ERR(bl))
-		return PTR_ERR(bl);
-	return 0;
+	return PTR_ERR_OR_ZERO(bl);
 static const struct of_device_id pm8941_wled_match_table[] = {
BtrLinux
Privacy Overview
