extcon: max77843: fix handling return value of regmap_irq_get_virq
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative values, so its result should
be assigned to signed variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Reviewed-by: Krzysztof Kozlowski
Signed-off-by: Chanwoo Choi
 drivers/extcon/extcon-max77843.c | 2 +-
diff --git a/drivers/extcon/extcon-max77843.c b/drivers/extcon/extcon-max77843.c
index 9f9ea33..74dfb7f 100644
--- a/drivers/extcon/extcon-max77843.c
+++ b/drivers/extcon/extcon-max77843.c
@@ -811,7 +811,7 @@ static int max77843_muic_probe(struct platform_device *pdev)
 	for (i = 0; i < ARRAY_SIZE(max77843_muic_irqs); i++) {
 		struct max77843_muic_irq *muic_irq = &max77843_muic_irqs[i];
-		unsigned int virq = 0;
+		int virq = 0;
 		virq = regmap_irq_get_virq(max77843->irq_data_muic,
 				muic_irq->irq);
BtrLinux
Privacy Overview
