pinctrl: rockchip: add missing of_node_put
for_each_child_of_node performs an of_node_get on each iteration, so a
return from the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
local idexpression n;
expression e,e1;
for_each_child_of_node(e1,n) {
of_node_put(n);
e = n
return n;
+ of_node_put(n);
? return ...;
Signed-off-by: Julia Lawall
Reviewed-by: Heiko Stuebner
Signed-off-by: Linus Walleij
drivers/pinctrl/pinctrl-rockchip.c | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/pinctrl/pinctrl-rockchip.c b/drivers/pinctrl/pinctrl-rockchip.c
index faab36e..9128826 100644
--- a/drivers/pinctrl/pinctrl-rockchip.c
+++ b/drivers/pinctrl/pinctrl-rockchip.c
@@ -1292,8 +1292,10 @@ static int rockchip_pinctrl_parse_functions(struct device_node *np,
func->groups[i] = child->name;
grp = &info->groups[grp_index++];
ret = rockchip_pinctrl_parse_groups(child, grp, info, i++);
- if (ret)
+ if (ret) {
+ of_node_put(child);
return ret;
return 0;
@@ -1338,6 +1340,7 @@ static int rockchip_pinctrl_parse_dt(struct platform_device *pdev,
ret = rockchip_pinctrl_parse_functions(child, info, i++);
if (ret) {
dev_err(&pdev->dev, "failed to parse function\n");
return ret;
- if (ret)
+ if (ret) {
return ret;
return 0;
if (ret) {
return ret;
