[media] media: use entity.graph_obj.mdev instead of .parent
Author: Javier Martinez Canillas <javier@osg.samsung.com>
The struct media_entity has a .parent field that stores a pointer
to the parent struct media_device. But recently a media_gobj was
embedded into the entities and since struct media_gojb already has
a pointer to a struct media_device in the .mdev field, the .parent
field becomes redundant and can be removed.
This patch replaces all the usage of .parent by .graph_obj.mdev so
that field will become unused and can be removed on a later patch.
No functional changes.
The transformation was made using the following coccinelle spatch:
struct media_entity *me;
- me->parent
+ me->graph_obj.mdev
struct media_entity *link;
- link->source->entity->parent
+ link->source->entity->graph_obj.mdev
struct exynos_video_entity *ve;
- ve->vdev.entity.parent
+ ve->vdev.entity.graph_obj.mdev
Suggested-by: Mauro Carvalho Chehab
Signed-off-by: Javier Martinez Canillas
Acked-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/media-device.c                       |  8 ++---
 drivers/media/media-entity.c                       | 34 ++++++++++++----------
 drivers/media/platform/exynos4-is/fimc-isp-video.c |  6 ++--
 drivers/media/platform/exynos4-is/fimc-lite.c      |  8 ++---
 drivers/media/platform/exynos4-is/media-dev.c      |  2 +-
 drivers/media/platform/exynos4-is/media-dev.h      |  8 ++---
 drivers/media/platform/omap3isp/isp.c              |  4 +--
 drivers/media/platform/omap3isp/ispvideo.c         |  2 +-
 drivers/media/platform/vsp1/vsp1_video.c           |  2 +-
 drivers/media/platform/xilinx/xilinx-dma.c         |  2 +-
 drivers/staging/media/davinci_vpfe/vpfe_video.c    |  6 ++--
 drivers/staging/media/omap4iss/iss.c               |  4 +--
 drivers/staging/media/omap4iss/iss_video.c         |  2 +-
 13 files changed, 45 insertions(+), 43 deletions(-)
diff --git a/drivers/media/media-device.c b/drivers/media/media-device.c
index 0f38444..138b184 100644
--- a/drivers/media/media-device.c
+++ b/drivers/media/media-device.c
@@ -435,8 +435,8 @@ int __must_check media_device_register_entity(struct media_device *mdev,
 	int i;
 	/* Warn if we apparently re-register an entity */
-	WARN_ON(entity->parent != NULL);
-	entity->parent = mdev;
+	WARN_ON(entity->graph_obj.mdev != NULL);
+	entity->graph_obj.mdev = mdev;
 	spin_lock(&mdev->lock);
 	/* Initialize media_gobj embedded at the entity */
@@ -471,7 +471,7 @@ EXPORT_SYMBOL_GPL(media_device_register_entity);
 void media_device_unregister_entity(struct media_entity *entity)
 	int i;
-	struct media_device *mdev = entity->parent;
+	struct media_device *mdev = entity->graph_obj.mdev;
 	if (mdev == NULL)
 		return;
@@ -484,7 +484,7 @@ void media_device_unregister_entity(struct media_entity *entity)
 	media_gobj_remove(&entity->graph_obj);
 	list_del(&entity->list);
 	spin_unlock(&mdev->lock);
-	entity->parent = NULL;
+	entity->graph_obj.mdev = NULL;
 EXPORT_SYMBOL_GPL(media_device_unregister_entity);
diff --git a/drivers/media/media-entity.c b/drivers/media/media-entity.c
index e840da0..6ed4a19 100644
--- a/drivers/media/media-entity.c
+++ b/drivers/media/media-entity.c
@@ -332,7 +332,7 @@ EXPORT_SYMBOL_GPL(media_entity_graph_walk_next);
 __must_check int media_entity_pipeline_start(struct media_entity *entity,
 					     struct media_pipeline *pipe)
 	struct media_entity_graph graph;
 	struct media_entity *entity_err = entity;
 	int ret;
@@ -387,7 +387,7 @@ __must_check int media_entity_pipeline_start(struct media_entity *entity,
 			ret = entity->ops->link_validate(link);
 			if (ret < 0 && ret != -ENOIOCTLCMD) {
-				dev_dbg(entity->parent->dev,
+				dev_dbg(entity->graph_obj.mdev->dev,
 					"link validation failed for \"%s\":%u -> \"%s\":%u, error %d\n",
 					link->source->entity->name,
 					link->source->index,
@@ -401,7 +401,7 @@ __must_check int media_entity_pipeline_start(struct media_entity *entity,
 		if (!bitmap_full(active, entity->num_pads)) {
 			ret = -EPIPE;
 				"\"%s\":%u must be connected by an enabled link\n",
 				entity->name,
 				(unsigned)find_first_zero_bit(
@@ -454,7 +454,7 @@ EXPORT_SYMBOL_GPL(media_entity_pipeline_start);
 void media_entity_pipeline_stop(struct media_entity *entity)
 	mutex_lock(&mdev->graph_mutex);
@@ -490,8 +490,8 @@ struct media_entity *media_entity_get(struct media_entity *entity)
 	if (entity == NULL)
 		return NULL;
-	if (entity->parent->dev &&
-	    !try_module_get(entity->parent->dev->driver->owner))
+	if (entity->graph_obj.mdev->dev &&
+	    !try_module_get(entity->graph_obj.mdev->dev->driver->owner))
 		return NULL;
 	return entity;
@@ -511,8 +511,8 @@ void media_entity_put(struct media_entity *entity)
 	if (entity == NULL)
 		return;
-	if (entity->parent->dev)
-		module_put(entity->parent->dev->driver->owner);
+	if (entity->graph_obj.mdev->dev)
+		module_put(entity->graph_obj.mdev->dev->driver->owner);
 EXPORT_SYMBOL_GPL(media_entity_put);
@@ -561,7 +561,8 @@ media_create_pad_link(struct media_entity *source, u16 source_pad,
 	link->flags = flags;
 	/* Initialize graph object embedded at the new link */
-	media_gobj_init(source->parent, MEDIA_GRAPH_LINK, &link->graph_obj);
+	media_gobj_init(source->graph_obj.mdev, MEDIA_GRAPH_LINK,
+			&link->graph_obj);
 	/* Create the backlink. Backlinks are used to help graph traversal and
 	 * are not reported to userspace.
@@ -577,7 +578,8 @@ media_create_pad_link(struct media_entity *source, u16 source_pad,
 	backlink->flags = flags;
-	media_gobj_init(sink->parent, MEDIA_GRAPH_LINK, &backlink->graph_obj);
+	media_gobj_init(sink->graph_obj.mdev, MEDIA_GRAPH_LINK,
+			&backlink->graph_obj);
 	link->reverse = backlink;
 	backlink->reverse = link;
@@ -629,12 +631,12 @@ EXPORT_SYMBOL_GPL(__media_entity_remove_links);
 void media_entity_remove_links(struct media_entity *entity)
 	/* Do nothing if the entity is not registered. */
-	if (entity->parent == NULL)
+	if (entity->graph_obj.mdev == NULL)
 		return;
-	mutex_lock(&entity->parent->graph_mutex);
+	mutex_lock(&entity->graph_obj.mdev->graph_mutex);
 	__media_entity_remove_links(entity);
-	mutex_unlock(&entity->parent->graph_mutex);
+	mutex_unlock(&entity->graph_obj.mdev->graph_mutex);
 EXPORT_SYMBOL_GPL(media_entity_remove_links);
@@ -703,7 +705,7 @@ int __media_entity_setup_link(struct media_link *link, u32 flags)
 	    (source->stream_count || sink->stream_count))
 		return -EBUSY;
-	mdev = source->parent;
+	mdev = source->graph_obj.mdev;
 	if (mdev->link_notify) {
 		ret = mdev->link_notify(link, flags,
@@ -724,9 +726,9 @@ int media_entity_setup_link(struct media_link *link, u32 flags)
 	int ret;
-	mutex_lock(&link->source->entity->parent->graph_mutex);
+	mutex_lock(&link->source->entity->graph_obj.mdev->graph_mutex);
 	ret = __media_entity_setup_link(link, flags);
-	mutex_unlock(&link->source->entity->parent->graph_mutex);
+	mutex_unlock(&link->source->entity->graph_obj.mdev->graph_mutex);
 	return ret;
diff --git a/drivers/media/platform/exynos4-is/fimc-isp-video.c b/drivers/media/platform/exynos4-is/fimc-isp-video.c
index 817226d..239df7d 100644
--- a/drivers/media/platform/exynos4-is/fimc-isp-video.c
+++ b/drivers/media/platform/exynos4-is/fimc-isp-video.c
@@ -287,7 +287,7 @@ static int isp_video_open(struct file *file)
 		goto rel_fh;
 	if (v4l2_fh_is_singular_file(file)) {
-		mutex_lock(&me->parent->graph_mutex);
+		mutex_lock(&me->graph_obj.mdev->graph_mutex);
 		ret = fimc_pipeline_call(ve, open, me, true);
@@ -295,7 +295,7 @@ static int isp_video_open(struct file *file)
 		if (ret == 0)
 			me->use_count++;
-		mutex_unlock(&me->parent->graph_mutex);
+		mutex_unlock(&me->graph_obj.mdev->graph_mutex);
 	if (!ret)
 		goto unlock;
@@ -311,7 +311,7 @@ static int isp_video_release(struct file *file)
 	struct fimc_isp *isp = video_drvdata(file);
 	struct fimc_is_video *ivc = &isp->video_capture;
 	struct media_entity *entity = &ivc->ve.vdev.entity;
 	mutex_lock(&isp->video_lock);
diff --git a/drivers/media/platform/exynos4-is/fimc-lite.c b/drivers/media/platform/exynos4-is/fimc-lite.c
index 2ce6704..11d2571 100644
--- a/drivers/media/platform/exynos4-is/fimc-lite.c
+++ b/drivers/media/platform/exynos4-is/fimc-lite.c
@@ -494,7 +494,7 @@ static int fimc_lite_open(struct file *file)
 	    atomic_read(&fimc->out_path) != FIMC_IO_DMA)
 		goto unlock;
 	ret = fimc_pipeline_call(&fimc->ve, open, me, true);
@@ -502,7 +502,7 @@ static int fimc_lite_open(struct file *file)
 	if (ret == 0)
 		me->use_count++;
 	if (!ret) {
 		fimc_lite_clear_event_counters(fimc);
@@ -535,9 +535,9 @@ static int fimc_lite_release(struct file *file)
 		fimc_pipeline_call(&fimc->ve, close);
 		clear_bit(ST_FLITE_IN_USE, &fimc->state);
 		entity->use_count--;
 	_vb2_fop_release(file, NULL);
diff --git a/drivers/media/platform/exynos4-is/media-dev.c b/drivers/media/platform/exynos4-is/media-dev.c
index 4c524a0..a67b986 100644
--- a/drivers/media/platform/exynos4-is/media-dev.c
+++ b/drivers/media/platform/exynos4-is/media-dev.c
@@ -1046,7 +1046,7 @@ static int __fimc_md_modify_pipeline(struct media_entity *entity, bool enable)
 	return ret;
-/* Locking: called with entity->parent->graph_mutex mutex held. */
+/* Locking: called with entity->graph_obj.mdev->graph_mutex mutex held. */
 static int __fimc_md_modify_pipelines(struct media_entity *entity, bool enable)
diff --git a/drivers/media/platform/exynos4-is/media-dev.h b/drivers/media/platform/exynos4-is/media-dev.h
index 93a96126..e8845e1 100644
--- a/drivers/media/platform/exynos4-is/media-dev.h
+++ b/drivers/media/platform/exynos4-is/media-dev.h
@@ -164,8 +164,8 @@ struct fimc_sensor_info *source_to_sensor_info(struct fimc_source_info *si)
 static inline struct fimc_md *entity_to_fimc_mdev(struct media_entity *me)
-	return me->parent == NULL ? NULL :
-		container_of(me->parent, struct fimc_md, media_dev);
+	return me->graph_obj.mdev == NULL ? NULL :
+		container_of(me->graph_obj.mdev, struct fimc_md, media_dev);
 static inline struct fimc_md *notifier_to_fimc_md(struct v4l2_async_notifier *n)
@@ -175,12 +175,12 @@ static inline struct fimc_md *notifier_to_fimc_md(struct v4l2_async_notifier *n)
 static inline void fimc_md_graph_lock(struct exynos_video_entity *ve)
-	mutex_lock(&ve->vdev.entity.parent->graph_mutex);
+	mutex_lock(&ve->vdev.entity.graph_obj.mdev->graph_mutex);
 static inline void fimc_md_graph_unlock(struct exynos_video_entity *ve)
-	mutex_unlock(&ve->vdev.entity.parent->graph_mutex);
+	mutex_unlock(&ve->vdev.entity.graph_obj.mdev->graph_mutex);
 int fimc_md_set_camclk(struct v4l2_subdev *sd, bool on);
diff --git a/drivers/media/platform/omap3isp/isp.c b/drivers/media/platform/omap3isp/isp.c
index 6351f35..aa13b17 100644
--- a/drivers/media/platform/omap3isp/isp.c
+++ b/drivers/media/platform/omap3isp/isp.c
@@ -787,7 +787,7 @@ int omap3isp_pipeline_pm_use(struct media_entity *entity, int use)
 	int change = use ? 1 : -1;
 	int ret;
 	/* Apply use count to node. */
 	entity->use_count += change;
@@ -798,7 +798,7 @@ int omap3isp_pipeline_pm_use(struct media_entity *entity, int use)
 	if (ret < 0)
 		entity->use_count -= change;
 	return ret;
diff --git a/drivers/media/platform/omap3isp/ispvideo.c b/drivers/media/platform/omap3isp/ispvideo.c
index 0e12907..a2e53b3 100644
--- a/drivers/media/platform/omap3isp/ispvideo.c
+++ b/drivers/media/platform/omap3isp/ispvideo.c
@@ -226,7 +226,7 @@ static int isp_video_get_graph_data(struct isp_video *video,
 	struct media_entity *entity = &video->video.entity;
 	struct isp_video *far_end = NULL;
diff --git a/drivers/media/platform/vsp1/vsp1_video.c b/drivers/media/platform/vsp1/vsp1_video.c
index 516595c..c2b2281 100644
--- a/drivers/media/platform/vsp1/vsp1_video.c
+++ b/drivers/media/platform/vsp1/vsp1_video.c
@@ -380,7 +380,7 @@ static int vsp1_pipeline_validate(struct vsp1_pipeline *pipe,
 	unsigned int i;
 	int ret;
diff --git a/drivers/media/platform/xilinx/xilinx-dma.c b/drivers/media/platform/xilinx/xilinx-dma.c
index ce2d34d..4b84a0e 100644
--- a/drivers/media/platform/xilinx/xilinx-dma.c
+++ b/drivers/media/platform/xilinx/xilinx-dma.c
@@ -181,7 +181,7 @@ static int xvip_pipeline_validate(struct xvip_pipeline *pipe,
 	struct media_entity *entity = &start->video.entity;
 	unsigned int num_inputs = 0;
 	unsigned int num_outputs = 0;
diff --git a/drivers/staging/media/davinci_vpfe/vpfe_video.c b/drivers/staging/media/davinci_vpfe/vpfe_video.c
index daae720..6e0d037 100644
--- a/drivers/staging/media/davinci_vpfe/vpfe_video.c
+++ b/drivers/staging/media/davinci_vpfe/vpfe_video.c
@@ -130,7 +130,7 @@ __vpfe_video_get_format(struct vpfe_video_device *video,
 static void vpfe_prepare_pipeline(struct vpfe_video_device *video)
 	struct media_entity *entity = &video->video_dev.entity;
 	struct vpfe_pipeline *pipe = &video->pipe;
 	struct vpfe_video_device *far_end = NULL;
@@ -288,7 +288,7 @@ static int vpfe_pipeline_enable(struct vpfe_pipeline *pipe)
 	else
 		entity = &pipe->inputs[0]->video_dev.entity;
-	mdev = entity->parent;
+	mdev = entity->graph_obj.mdev;
 	media_entity_graph_walk_start(&graph, entity);
 	while ((entity = media_entity_graph_walk_next(&graph))) {
@@ -328,7 +328,7 @@ static int vpfe_pipeline_disable(struct vpfe_pipeline *pipe)
 	else
diff --git a/drivers/staging/media/omap4iss/iss.c b/drivers/staging/media/omap4iss/iss.c
index 60e67fa..b405dc9 100644
--- a/drivers/staging/media/omap4iss/iss.c
+++ b/drivers/staging/media/omap4iss/iss.c
@@ -494,7 +494,7 @@ int omap4iss_pipeline_pm_use(struct media_entity *entity, int use)
 	int ret;
@@ -505,7 +505,7 @@ int omap4iss_pipeline_pm_use(struct media_entity *entity, int use)
 	if (ret < 0)
 	return ret;
diff --git a/drivers/staging/media/omap4iss/iss_video.c b/drivers/staging/media/omap4iss/iss_video.c
index dd8ff03..ea38463 100644
--- a/drivers/staging/media/omap4iss/iss_video.c
+++ b/drivers/staging/media/omap4iss/iss_video.c
@@ -206,7 +206,7 @@ iss_video_far_end(struct iss_video *video)
 	struct iss_video *far_end = NULL;
BtrLinux
Privacy Overview
