staging: fsl-mc: Remove unneeded else following a return
Author: Janani Ravichandran <janani.rvchndrn@gmail.com>
Remove unnecessary else when there is a return statement in the
corresponding if block. Coccinelle patch used:
@rule1@
expression e1;
	if (e1) { ... return ...; }
-       else{
@rule2@
expression e2;
statement s1;
	if(e2) { ... return ...; }
-       else
               s1
Signed-off-by: Janani Ravichandran
 drivers/staging/fsl-mc/bus/mc-bus.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/fsl-mc/bus/mc-bus.c b/drivers/staging/fsl-mc/bus/mc-bus.c
index c42bfac..5958e0f 100644
--- a/drivers/staging/fsl-mc/bus/mc-bus.c
+++ b/drivers/staging/fsl-mc/bus/mc-bus.c
@@ -248,8 +248,7 @@ static bool fsl_mc_is_root_dprc(struct device *dev)
 	fsl_mc_get_root_dprc(dev, &root_dprc_dev);
 	if (!root_dprc_dev)
 		return false;
-	else
-		return dev == root_dprc_dev;
+	return dev == root_dprc_dev;
 static int get_dprc_icid(struct fsl_mc_io *mc_io,
BtrLinux
Privacy Overview
