gpio: xgene: fix type of variable containing error codes
Author: Andrzej Hajda <a.hajda@samsung.com>
ret variable can contain error values and is compared with zero.
Its type must be signed.
The problem has been detected using coccinelle script
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci
Signed-off-by: Andrzej Hajda
Signed-off-by: Linus Walleij
 drivers/gpio/gpio-xgene-sb.c | 2 +-
diff --git a/drivers/gpio/gpio-xgene-sb.c b/drivers/gpio/gpio-xgene-sb.c
index b993b86..fd81ebc 100644
--- a/drivers/gpio/gpio-xgene-sb.c
+++ b/drivers/gpio/gpio-xgene-sb.c
@@ -240,7 +240,7 @@ static const struct irq_domain_ops xgene_gpio_sb_domain_ops = {
 static int xgene_gpio_sb_probe(struct platform_device *pdev)
 	struct xgene_gpio_sb *priv;
-	u32 ret;
+	int ret;
 	struct resource *res;
 	void __iomem *regs;
 	struct irq_domain *parent_domain = NULL;
BtrLinux
Privacy Overview
