staging: android: ion: tegra: Use devm_kcalloc instead of devm_kzalloc
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace devm_kzalloc with devm_kcalloc to ensure there are no integer
overflows from the multiplication of a number * sizeof.
The following Coccinelle semantic patch was used to make this change:
expression dev,E1,E3;
type T;
- devm_kzalloc(dev,E1*sizeof(T),E3)
+ devm_kcalloc(dev,E1,sizeof(T),E3)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/android/ion/tegra/tegra_ion.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/android/ion/tegra/tegra_ion.c b/drivers/staging/android/ion/tegra/tegra_ion.c
index 4d3c516..8828524 100644
--- a/drivers/staging/android/ion/tegra/tegra_ion.c
+++ b/drivers/staging/android/ion/tegra/tegra_ion.c
@@ -33,9 +33,8 @@ static int tegra_ion_probe(struct platform_device *pdev)
 	num_heaps = pdata->nr;
-	heaps = devm_kzalloc(&pdev->dev,
-			     sizeof(struct ion_heap *) * pdata->nr,
-			     GFP_KERNEL);
+	heaps = devm_kcalloc(&pdev->dev, pdata->nr,
+			     sizeof(struct ion_heap *), GFP_KERNEL);
 	idev = ion_device_create(NULL);
 	if (IS_ERR_OR_NULL(idev))
BtrLinux
Privacy Overview
