gpu: host1x: bus: Add missing of_node_put()
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
for_each_child_of_node() performs an of_node_get() on each iteration, so
to break out of the loop an of_node_put() is required.
Found using Coccinelle. The semantic patch used for this is as follows:
expression e;
local idexpression n;
 for_each_child_of_node(..., n) {
   ... when != of_node_put(n)
       when != e = n
   return n;
+  of_node_put(n);
?  return ...;
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Thierry Reding
 drivers/gpu/host1x/bus.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/gpu/host1x/bus.c b/drivers/gpu/host1x/bus.c
index da462af..c2e7fba 100644
--- a/drivers/gpu/host1x/bus.c
+++ b/drivers/gpu/host1x/bus.c
@@ -82,8 +82,10 @@ static int host1x_device_parse_dt(struct host1x_device *device,
 		if (of_match_node(driver->subdevs, np) &&
 		    of_device_is_available(np)) {
 			err = host1x_subdev_add(device, np);
-			if (err < 0)
+			if (err < 0) {
+				of_node_put(np);
 				return err;
BtrLinux
Privacy Overview
