staging: iio: isl29028: use regmap to retrieve struct device
Author: Alison Schofield <amsfield22@gmail.com>
Driver includes struct regmap and struct device in its global data.
Remove the struct device and use regmap API to retrieve device info.
Simplified version of Coccinelle semantic patch used:
@ a @
identifier drvdata, r;
position p;
  struct drvdata@p {
  struct regmap *r;
@ b @
identifier a.drvdata, d;
position a.p;
  struct drvdata@p {
- struct device *d;
@ passed depends on b @
identifier a.drvdata, a.r, b.d, i, f;
  f (..., struct drvdata *i ,...) {
+ struct device *dev = regmap_get_device(i->r);
-	   i->d
+	   dev
Signed-off-by: Alison Schofield
Signed-off-by: Jonathan Cameron
 drivers/staging/iio/light/isl29028.c | 55 ++++++++++++++++++++----------------
 1 file changed, 30 insertions(+), 25 deletions(-)
diff --git a/drivers/staging/iio/light/isl29028.c b/drivers/staging/iio/light/isl29028.c
index 6e2ba45..2e3b1d6 100644
--- a/drivers/staging/iio/light/isl29028.c
+++ b/drivers/staging/iio/light/isl29028.c
@@ -69,7 +69,6 @@ enum als_ir_mode {
 struct isl29028_chip {
-	struct device		*dev;
 	struct mutex		lock;
 	struct regmap		*regmap;
@@ -166,20 +165,21 @@ static int isl29028_set_als_ir_mode(struct isl29028_chip *chip,
 static int isl29028_read_als_ir(struct isl29028_chip *chip, int *als_ir)
+	struct device *dev = regmap_get_device(chip->regmap);
 	unsigned int lsb;
 	unsigned int msb;
 	int ret;
 	ret = regmap_read(chip->regmap, ISL29028_REG_ALSIR_L, &lsb);
 	if (ret < 0) {
-		dev_err(chip->dev,
+		dev_err(dev,
 			"Error in reading register ALSIR_L err %d\n", ret);
 		return ret;
 	ret = regmap_read(chip->regmap, ISL29028_REG_ALSIR_U, &msb);
 	if (ret < 0) {
+		dev_err(dev,
 			"Error in reading register ALSIR_U err %d\n", ret);
 		return ret;
@@ -190,12 +190,13 @@ static int isl29028_read_als_ir(struct isl29028_chip *chip, int *als_ir)
 static int isl29028_read_proxim(struct isl29028_chip *chip, int *prox)
 	unsigned int data;
 	int ret;
 	ret = regmap_read(chip->regmap, ISL29028_REG_PROX_DATA, &data);
 	if (ret < 0) {
-		dev_err(chip->dev, "Error in reading register %d, error %d\n",
+		dev_err(dev, "Error in reading register %d, error %d\n",
 			ISL29028_REG_PROX_DATA, ret);
 		return ret;
@@ -218,13 +219,14 @@ static int isl29028_proxim_get(struct isl29028_chip *chip, int *prox_data)
 static int isl29028_als_get(struct isl29028_chip *chip, int *als_data)
 	int ret;
 	int als_ir_data;
 	if (chip->als_ir_mode != MODE_ALS) {
 		ret = isl29028_set_als_ir_mode(chip, MODE_ALS);
 		if (ret < 0) {
+			dev_err(dev,
 				"Error in enabling ALS mode err %d\n", ret);
 			return ret;
@@ -251,12 +253,13 @@ static int isl29028_als_get(struct isl29028_chip *chip, int *als_data)
 static int isl29028_ir_get(struct isl29028_chip *chip, int *ir_data)
 	int ret;
 	if (chip->als_ir_mode != MODE_IR) {
 		ret = isl29028_set_als_ir_mode(chip, MODE_IR);
 		if (ret < 0) {
+			dev_err(dev,
 				"Error in enabling IR mode err %d\n", ret);
 			return ret;
@@ -271,25 +274,26 @@ static int isl29028_write_raw(struct iio_dev *indio_dev,
 			      int val, int val2, long mask)
 	struct isl29028_chip *chip = iio_priv(indio_dev);
 	int ret = -EINVAL;
 	mutex_lock(&chip->lock);
 	switch (chan->type) {
 	case IIO_PROXIMITY:
 		if (mask != IIO_CHAN_INFO_SAMP_FREQ) {
+			dev_err(dev,
 				"proximity: mask value 0x%08lx not supported\n",
 				mask);
 			break;
 		if (val < 1 || val > 100) {
+			dev_err(dev,
 				"Samp_freq %d is not in range[1:100]\n", val);
 			break;
 		ret = isl29028_set_proxim_sampling(chip, val);
 		if (ret < 0) {
+			dev_err(dev,
 				"Setting proximity samp_freq fail, err %d\n",
 				ret);
 			break;
@@ -299,19 +303,19 @@ static int isl29028_write_raw(struct iio_dev *indio_dev,
 	case IIO_LIGHT:
 		if (mask != IIO_CHAN_INFO_SCALE) {
+			dev_err(dev,
 				"light: mask value 0x%08lx not supported\n",
 				mask);
 			break;
 		if ((val != 125) && (val != 2000)) {
+			dev_err(dev,
 				"lux scale %d is invalid [125, 2000]\n", val);
 			break;
 		ret = isl29028_set_als_scale(chip, val);
 		if (ret < 0) {
+			dev_err(dev,
 				"Setting lux scale fail with error %d\n", ret);
 			break;
@@ -319,7 +323,7 @@ static int isl29028_write_raw(struct iio_dev *indio_dev,
 		break;
 	default:
-		dev_err(chip->dev, "Unsupported channel type\n");
+		dev_err(dev, "Unsupported channel type\n");
 		break;
 	mutex_unlock(&chip->lock);
@@ -331,6 +335,7 @@ static int isl29028_read_raw(struct iio_dev *indio_dev,
 			     int *val, int *val2, long mask)
 	int ret = -EINVAL;
@@ -370,7 +375,7 @@ static int isl29028_read_raw(struct iio_dev *indio_dev,
 		break;
 	default:
-		dev_err(chip->dev, "mask value 0x%08lx not supported\n", mask);
+		dev_err(dev, "mask value 0x%08lx not supported\n", mask);
 		break;
@@ -417,6 +422,7 @@ static const struct iio_info isl29028_info = {
 static int isl29028_chip_init(struct isl29028_chip *chip)
 	int ret;
 	chip->enable_prox  = false;
@@ -426,35 +432,33 @@ static int isl29028_chip_init(struct isl29028_chip *chip)
 	ret = regmap_write(chip->regmap, ISL29028_REG_TEST1_MODE, 0x0);
 	if (ret < 0) {
-		dev_err(chip->dev, "%s(): write to reg %d failed, err = %d\n",
+		dev_err(dev, "%s(): write to reg %d failed, err = %d\n",
 			__func__, ISL29028_REG_TEST1_MODE, ret);
 		return ret;
 	ret = regmap_write(chip->regmap, ISL29028_REG_TEST2_MODE, 0x0);
 	if (ret < 0) {
 			__func__, ISL29028_REG_TEST2_MODE, ret);
 		return ret;
 	ret = regmap_write(chip->regmap, ISL29028_REG_CONFIGURE, 0x0);
 	if (ret < 0) {
 			__func__, ISL29028_REG_CONFIGURE, ret);
 		return ret;
 	ret = isl29028_set_proxim_sampling(chip, chip->prox_sampling);
 	if (ret < 0) {
-		dev_err(chip->dev, "setting the proximity, err = %d\n",
-			ret);
+		dev_err(dev, "setting the proximity, err = %d\n", ret);
 		return ret;
 	ret = isl29028_set_als_scale(chip, chip->lux_scale);
 	if (ret < 0)
-			"setting als scale failed, err = %d\n", ret);
+		dev_err(dev, "setting als scale failed, err = %d\n", ret);
 	return ret;
@@ -496,19 +500,19 @@ static int isl29028_probe(struct i2c_client *client,
 	i2c_set_clientdata(client, indio_dev);
-	chip->dev = &client->dev;
 	mutex_init(&chip->lock);
 	chip->regmap = devm_regmap_init_i2c(client, &isl29028_regmap_config);
 	if (IS_ERR(chip->regmap)) {
 		ret = PTR_ERR(chip->regmap);
-		dev_err(chip->dev, "regmap initialization failed: %d\n", ret);
+		dev_err(&client->dev, "regmap initialization failed: %d\n",
+			ret);
 		return ret;
 	ret = isl29028_chip_init(chip);
 	if (ret < 0) {
-		dev_err(chip->dev, "chip initialization failed: %d\n", ret);
+		dev_err(&client->dev, "chip initialization failed: %d\n", ret);
 		return ret;
@@ -520,7 +524,8 @@ static int isl29028_probe(struct i2c_client *client,
 	indio_dev->modes = INDIO_DIRECT_MODE;
 	ret = devm_iio_device_register(indio_dev->dev.parent, indio_dev);
 	if (ret < 0) {
-		dev_err(chip->dev, "iio registration fails with error %d\n",
+			"iio registration fails with error %d\n",
 			ret);
 		return ret;
BtrLinux
Privacy Overview
